ls6 cam in 5.3
Old Apr 14, 2019 | 12:29 PM
Jona91's Avatar
Default ls6 cam in 5.3
Im planning on swapping my castech heads with some home ported 862 noncastech heads on my 04 5.3. I was going to get a 212/218 .600 112 cam. I seen people also put ls6 cams. The thing is doesn't the ls6 make all the power in the higher rpm range since they're 117 and 116 lsa? I have a crew cab and want some power in the low rpm also. It has 3.73 stock gears.
2001Corvette Z06 204/211 525 116lsa
2002-04Corvette 204/218 555/.551 117.5lsa
Should I just spends the extra couple hundred just for the 216/220 from tsp and some springs?
Old Apr 14, 2019 | 05:51 PM
FFDP's Avatar
I think you'd be happier with a camshaft more designed for the truck application. The 212/218 size is perfect for the stock converter.
Old Apr 14, 2019 | 11:15 PM
arthursc2's Avatar
Absolutely love my 212/218 .550 in my Tahoe. Went to it from an LS9 cam and even with boost the 212 is better in every way I can think of
Old Apr 15, 2019 | 07:28 AM
GREENSIERRA's Avatar
I put a 212 218 cam with milled 243s in my wifes lifted Tahoe that has a l33 in it.
Perfect cam for a stock converter in something heavier.
Old Apr 15, 2019 | 10:24 AM
ZO6Ted's Avatar
Yeah don't put the ls6 in it doesn't light up until over 3k at least.
mr 5.3
Jan 6, 2012 09:20 AM
beastmode
Aug 22, 2011 05:10 PM
Rick_Vor
Dec 12, 2008 12:24 PM
jcolbyh
Jan 30, 2008 02:22 PM
1slow01Z71
Oct 21, 2006 04:09 PM
