LS6 cam in 4.8L?
Originally Posted by Tiburon
Which ls6 cam was put in this 4.8 you talk about?
it was my 4.8 that richard is talking about, I have about 20 dyno pulls with that cam. I took it out because it was a filthy ***** below 3500 rpms. It made tons of power after about 4500 rpms, richard will tell you it pulled like a bear. I dynoed @ 289 rwhp with that cam with headers, stock exhaust, ls1 edit & an cold air kit. It would be an awsome nitrous cam, smooth idle, but it is design for a lightweight 6 speed, not a heavy truck. I did it the first time because it was dirt cheap here at the dealership. I defenitly reccomend degreeing it & using a stall.
You had the 02+ cam in there. The 01 ls6 cam(204/211 .525/.525 116) would have pulled better down low.
you still have an enormous amount of lsa, you are only losing 1.5 degrees. I have now the 212/218 114 lsa .529/.532. In wathching the air flow across the maf between the two I had more airflow after 5000 rpms with the ls6 vs. this one, however the 212/218 makes quite a bit more on the bottom end.
Don't get me wrong it made a good hp, but the first time you line up against a stock 5.3 & he jumps out on you don't get your feelings hurt.
I agree, if going with an LS6 cam in the 4.8 use the 01 model.
I used the 01 on the stroker motor to help with the top end ( the stroke increase will help low torque ) and also cuz of the emission sniffers. The GM parts will pass emissions while some of the aftermarket ones with smaller LSA make me nervous.
i have an 06 with the 4.8L and a ls6 cam, long tube headers and cold air intake my buddy has a 02 reg cab 5.3 stock...he beat me off the line and but i got him down the track like they said the pull doent start till about 3000
RPMs. thats with 342s im thinking about going 410s and a retune from nelson performance if that doesnt fix it ill get a 2800-3000 stall put in
ARC
57
Feb 21, 2022 10:54 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
