LS2 heads on a 5.3?
Old Aug 4, 2007 | 12:23 AM
fastrt's Avatar
11 Second Truck Club
Default LS2 heads on a 5.3?
My buddy has a 05 gto and he wants to put L92 heads on it and he will almost give me these LS2 heads if I help him build the l92 heads. Any one done this swap, or have opinions?
Old Aug 4, 2007 | 12:28 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Which 5.3L do you have? Your CR will drop.
Old Aug 4, 2007 | 12:42 AM
Quik's Avatar
5 year bitches!
243s have been installed on 5.3 from the factory so yes they will work
Old Aug 4, 2007 | 12:45 AM
trever1t's Avatar
799's/243's have been installed on 5.3's with flattop pistons making 9.9:1 CR. Using them on the standard dished pistons would drop CR to ?
Old Aug 4, 2007 | 12:46 AM
RandomHero's Avatar
Aren't the heads like 65cc stock? Seems like a recipe for compression loss. The only way it might be worth it is if you had them milled down for compression.
I believe sportside did that and didn't gain hardly anything though.
Old Aug 4, 2007 | 02:39 PM
fastrt's Avatar
L59 06'
Old Aug 4, 2007 | 03:07 PM
Quik's Avatar
5 year bitches!
64.5cc and roughly ever .5 in cr is roughly 20hp
Old Aug 4, 2007 | 03:59 PM
Sport Side's Avatar
....and roughly ever .5 in cr is roughly 20hp
No way. You got anything to back that up?
Old Aug 4, 2007 | 04:41 PM
Quik's Avatar
5 year bitches!
yes do a search, i found that in a mustang book along with being backed up several times on the net and in other books/magizines. that is BHP not WHP
exactly why same setups and if you play with compression the one with higher cr will have slightly more power
heres one for ya....LQ4 vs LQ9 they are the same motors down to the T minus compression...this is just one example
Old Aug 4, 2007 | 05:01 PM
Grumpy5.3's Avatar
Originally Posted by fastrt
L59 06'
you need to see what you have on your engine. I fyou already have 243s, or 799s, you will be wasting alot of time and money unless you get them shaved and spend money on them...
