LS2 Cam into a 5.3?
Old May 26, 2014 | 01:15 AM
TXsilverado's Avatar
Originally Posted by gamble686
Come on you have done enough cam swaps to know the gaskets, bolts, guilds etc will cost a lot more than that to get it done.
You will need yellow springs at minimum. Hardened pushrods are a good idea while you're in there since the stock ones aren't so strong when spinning that motor up. It can snowball from there.
how many stock pushrods have you ever seen bend? I know a guy with a T-REX cam spinning 7,500 rpm on stock pushrods. what gaskets? reuse the stockers. yellow springs are cheap. $50 for my cam, $50 for yellow springs.
Old May 26, 2014 | 06:10 AM
Chevy_King1500's Avatar
you do need to purchase a new crank bolt. other than that you're set. also coolant
Old May 26, 2014 | 07:41 AM
}BlueFire{'s Avatar
https://sdparts.com/details/gm-factory-replacement-parts/12633906
https://sdparts.com/details/scoggin-dickey-parts-center/cas109081
http://www.briantooleyracing.com/ls2-single-pole-timing-chain-gear-12576407.html
Here are the parts needed minus springs depending what 5.3 you have. Plus need crank bolt and coolant as others have said.
Old May 26, 2014 | 08:19 AM
}BlueFire{'s Avatar
For what its worth I did an ls2 cam on my 5.3 swapped trans am. I had an l33 that has 799 heads and 9.9:1 compression. Full bolt ons on a dynojet put down 371 hp and 348 torque.
My buddy has an ls1 trans am with 04 ls6 cam and ls6 heads also full bolt ons. Same dyno put down 393 HP and 377 torque.
Both auto's, I had ls6 intake vs his ssi intake, my cam specs 204/211@.050 .525/.525 lift 116 LSA. His 204/218@.050 .550/.550 lift 117.5 LSA. The 23ci, .6 compression, slightly wider LSA, slightly higher lift and few degrees more exhaust plus a supposed better intake netted him 22 HP and 29 tq over my set up.
However with most 5.3 dynos I see well under the 300 range for bolt ons. I think I faired pretty well for comparison sake. However if this is in a truck I've read over n over you lose a LOT of torque off idle. Right where it counts in a heavy pig.
Old May 27, 2014 | 09:07 PM
Z28RPM's Avatar
11 Second Club
I had a LS6 cam in my 5.3 and hated it. Had no torque down low but felt great above 4k. Low torque is everything for a heavy truck!!
Old May 27, 2014 | 09:16 PM
gamble686's Avatar
Damn that's a scary proposition risking a lot more than just the pushrods running stockers. I have seen two sets bent in person both on stock cams. More than likely from age/use one had over 200k on the clock and the other over 150k. Both failed after spinning no more than 6400. I think it's pretty well accepted that push rods are included in every cam kit I have ever seen. Not saying it can't be done, but I sure as hell think its worth the money. I was thinking timing cover gasket water pump gasket amongst other things.
Old May 27, 2014 | 09:53 PM
i run upgraded pushrods too...just showing that it can be done. he abuses his engines too. never had a problem running stock pushrods with single springs.
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
Ammadien
Jul 22, 2015 08:50 PM
06 4.8
Jul 15, 2015 07:17 PM
caviness
Jul 5, 2015 10:49 PM
