LS2 90mm intake.....
Originally Posted by cbrich
The LS2 throttle body is electronic, not cable. If you want a 90 mm cable activated throttle body, Fuel Air Spark Technology (FAST) has one, part #30-54008.
Now I know what your question is, the LS2 intake is pretty much the same as the LS6 except it provides the clearance around the sensors that have been moved and the TB is slightly angle up to reduce water puddle in TB. Here is the site I found about the LS2.
