is LS1 throttlebody a upgrade for lm7?
Old Jun 9, 2011 | 10:22 AM
flippindabird's Avatar
Default is LS1 throttlebody a upgrade for lm7?
im wondering if the stock ls1 throttlebody is bigger then the LM7 stock throttlebody and is it an upgrade? what size are the tb's ? i did a search and came up with nothing, im thinkin a good sticky would be a "all factory upgrade parts" thread so we could have all this info in 1 place
Old Jun 9, 2011 | 12:21 PM
01GMC5.3's Avatar
nope it is the same size
Old Jun 9, 2011 | 05:35 PM
thanks for the quick reply i searched and couldnt find a definate answer
Old Jun 9, 2011 | 06:00 PM
kr1s's Avatar
Really? Hm... i wanted to swap a ls6 intake on a lm7
Old Jun 9, 2011 | 08:52 PM
i read in CHP i believe, that there wasnt much gain from the truck manifold to the LS6 and they actually lost changing from the truck manifold to the LS1... i do however think that the TB is bigger then the truck TB but i could definately be wrong... someone else please correct me if i am...
after thinking about it further if the LS6 intake flows more then the truck intake, then the composite plastic intakes heat dissipating effects would probably help make a fair gain, if you could get one cheaply it would probably be worth it
Old Jun 9, 2011 | 10:10 PM
terravast4's Avatar
I believe the truck intake makes far more torque than the ls6
Old Jun 9, 2011 | 11:42 PM
bmd_CL's Avatar
with an ls6 intake you lose what a truck needs most...torque.
Old Jun 10, 2011 | 12:42 AM
kr1s's Avatar
So which after market intake would you say is best for a lm7
Lol and not one that cost like 700$
Old Jun 10, 2011 | 02:14 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'd recommend the intake from Magnacharger, if you want torque. And it doesn't cost $700. So it matches your needs perfectly!
Old Jun 10, 2011 | 07:17 AM
lol @ ^^^^^^
keep the truck intake unless you get more cubes
lxcoupe
13
Nov 20, 2015 08:43 PM
TrickTurbo
Sep 23, 2015 08:41 PM
Noah Burns
Sep 13, 2015 09:28 AM
sTNT971
Sep 11, 2015 02:38 AM
screaminian47
Sep 7, 2015 08:20 PM
