Ls1 swapped silverado -help plz!
Old Feb 13, 2018 | 10:50 AM
Chuy-nator's Avatar
Default Ls1 swapped silverado -help plz!
i have a 2000 silverado, came stock with the 4.3L v6 engine which I have removed completely with transmission and pcm & harness...I installed a fully built ls1 engine and it’s origi 4l60e trans I used a harness out of a 2001 silverado 5.3l which plugged in straight into my pcm... I’m having trouble getting it started I have plugged everything in and the key doesn’t seem to make the truck run...I tried starting it from the solenoid and started by touching the two leads and it seems to crank and it turns on for a quick second and than it shuts off...I have spark and fuel pressure....a friend of mine said maybe because the pcm belonged to a camaro and the truck wiring is diff might be the issue ...another said to make sure all the grounds in the harness are connected...any suggestions or past experiences anyone had related to this issue?
Old Feb 13, 2018 | 11:06 AM
03sierraslt's Avatar
Did you do the passlock procedure? Sounds like it may be active.
Old Feb 13, 2018 | 12:56 PM
Chuy-nator's Avatar
how do I go about doing that? I just checked all my grounds so that’s good!
Old Feb 13, 2018 | 02:56 PM
About20ninj45's Avatar
How To Reset Passlock and Passkey VATS System | Passlock ? GM Security System
99whipple
Mar 25, 2013 08:16 PM
bolikes2skate
Nov 16, 2009 10:01 PM
V8sonoma
Nov 4, 2008 08:49 PM
ME Performance
11
Sep 27, 2006 08:54 AM
VicRed
45
Dec 29, 2004 06:55 PM
