ls1 swap guys come in....please.
Mods are in sig, the 12.2 was at +1500 da. heads are gm performance 243s with 61.9 cc chambers and I ran the math and its 10.8-1, you need 60 cc chambers to get 11-1. I cant say id really change much on my setup, im shur theres a bit more in it with different heads and a composit intake but i like the cam and stall setup alot. If you want more cam then mine you may have to tweek the converter a bit.. 4200-4400 to get the crazy 60 foot. Iv done a few 6.0 setups and these ls1s hurt on the mid range torque compared to the 6.0 so they need quite a bit of stall in them.
11 Second Truck Club
From what Pat G sent me in my email with this 230/234 600/602 111+1 EPS cam im getting my compression should be 11.0:1 with my 243's being milled .015 using a stock GM head gasket. But I have never used a compression calculator so yall probably know more than me about it
Whos this "custom cam and valve spring" guy your using? lol
Forged internals sound nice for a big shot of the gas
. Sounds like it will be a stout setup. The next thing ill be getting for my LS1 is a FAST LSXrt but that wont be for a long while lol. Need to get a good transmission and differential first.
. Sounds like it will be a stout setup. The next thing ill be getting for my LS1 is a FAST LSXrt but that wont be for a long while lol. Need to get a good transmission and differential first.as far as the guy doing the work........have you ever wondered who does the port work and r&d on big race team heads, nascar, prostock, pro mod, big grudge racers, ect? ever wonder who designs the cnc work on say trickflow heads? I found who......
11:1 sounds right. I am having lots of work done to these 799's, so I will have to mill more due to the port work. I talked to my guy tonight when I payed him to get started on my heads, and he is getting the cam specs tomorrow. should be 232 to 235 on the intake side and 236-240 on the exaust side. It sure is hard to shell out the money......
Eric, my heads look **** after he finished with them, I still need to pick up shims and seals before i put the heads on.
I know he made 505hp out of a H/C/I LS6 in his car.
The guy really knows his stuff and my brain always hurts after leaving his shop because of the **** that i learn everytime i go out there. Anyways... too bad we cant get a 5.3-5.3 run in once i put the verter and heads on. That would've been fun
I know, but I dont mind sharing names and numbers if you want. just pm me. i dont want to get in trouble for soliciting work from a non sponser.
I learn new things about airflow every time I talk to him. I am ready to see the results. If I , and I think I will, forge it, I may go 11.5 or so.
I bet!! you should have seen the 7xx CI GM hemi headed all aluminum grudge racer motor he ported the heads on....wow I could have stuck my fist in the exaust runners. he said it should do 2000hp plus a heavy shot of N2O.
we still can
, I have lots more money to save up for this ls1. I want to forge it, and Chris is getting me a smokin deal on Manly pistons and rods. I need to sell my ls6 pistons and rods, and send back some stock rebuild parts I bought.
we still can
lxcoupe
Jul 21, 2015 02:12 AM
