ls1 pushrod vs a 4.8 pushrod
Old Mar 8, 2007 | 05:23 PM
javier4.8's Avatar
Default ls1 pushrod vs a 4.8 pushrod
is there a difference between the lengh of the pushrod of a ls1 and a 4.8. my friend wrecked his t/a and im needing new pushrods with the cam on my 4.8. what else can i get that can be usefull on my 4.8
Old Mar 8, 2007 | 08:05 PM
Tootall's Avatar
how do you know that you need newer rods? Are the ones that you're asking about, LS1s are they hardened?
Old Mar 8, 2007 | 08:23 PM
javier4.8's Avatar
i put a ls6 cam and other people have been telling me that i need longer pushrods.. or something
Old Mar 8, 2007 | 08:34 PM
DarkblueTA's Avatar
Unless GM changed something lately, everything is the same between LS1 vs 4.8/5.3 other then the bore sizes, intakes, intake valve size (1.88 trucks vs. 2.02 Fbodies) and manifolds/computer/wire harness.
Old Mar 9, 2007 | 06:49 AM
LARRY01Z28's Avatar
i have read in some places that you may need longer pushrods if you use the 2002 z06 cam. because it has a smaller base circle
Old Mar 9, 2007 | 11:50 AM
TXsilverado's Avatar
ditto...not sure what size pushrod though. maybe hit the search button on ls1tech.com
Old Mar 15, 2007 | 05:08 AM
jonnyboy's Avatar
i'm pretty sure you need the 7.4" hardened pushrod for the 2002 ls6 cam to make up the difference for the 2002's smaller base circle; gm just used longer valves on this engine to make up the difference. you need hardened pushrods with this engine because your new redline will be around 6500 rpms after tuning for this cam.
Old Mar 15, 2007 | 12:58 PM
kbracing96's Avatar
FWIW, I ran a 02 LS6 cam for about 12k miles with my STOCK 4.8 push rods. The cam does have a .050 smaller base circle, so to be at the factory preload on the lifters, you would need .025 longer push rods, but there is enough travel in the stock hydraulic lifters to make up for the .025 difference.
AdaMax
May 16, 2016 11:35 PM
JordanH
Nov 6, 2015 07:42 PM
97_ek
Sep 23, 2015 09:16 PM
maxspeed05V
Sep 23, 2015 10:48 AM
Dawas
Sep 20, 2015 12:00 PM
