Ls1 Or Ls6 Whick Is It.
Old Nov 3, 2005 | 07:39 AM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by ap2002
212/218 has a high lift version too.. I believe it is a 212/218 .558/.563 115..
Yea, there's that one and a 222/224? high lift also, but not the 216/220 for some reason? Seems like a cam that would respond well to more lift.
Old Nov 3, 2005 | 09:44 AM
  #22
gonzo 6.2's Avatar
Originally Posted by whitt1
The LS6 valvesprings will work as will the LS6 cam,but the LS1 heads won't flow as much as a set of LS6 heads.You will need to check your push rod lengths because the LS6 cam has a bigger base circle on the 02 or later cam.
This explains why the base circle is smaller.Ls6 cam having bigger lobes are a givin.
http://www.idavette.net/hib/02ls6/page2.htm
Old Nov 3, 2005 | 07:41 PM
  #23
How about this set up.comp cams PT#cc54-414-11 216/220 525/532 114 form 1300 to 6300 rpm. then go with the comp cams 1.275 dual vale springs. do I really need the titanium retainers. let me know what you think. later
Old Nov 3, 2005 | 07:50 PM
  #24
gonzo 6.2's Avatar
With that cam you can use new Ls6 spring for $70,no need for the other ****.You might as well go for the free HP and go with 550-570 lift range even if your duration is in the 205-222 range,even then I would use those springs. 114LC is about the best all around.Do you feel the need to spin it past 6200?
Old Nov 6, 2005 | 04:44 AM
  #25
4.8LGMC's Avatar
that's what's great about all the new GEN III engines.....it's all interchangeable
Old Nov 6, 2005 | 10:23 AM
  #26
TurboGibbs's Avatar
Thats true but the gen1 small blocks are even more interchangable. The head flow doesn't compare though.
Old Nov 6, 2005 | 09:02 PM
  #27
brodystruck's Avatar
Originally Posted by Rob'sGMCSS
It came out of a reagular C5. so what would be the specs on this engine. Would I have to swap out the valve springs to put in this cam.220/224 0.551/0.551-114ls.
Originally Posted by 99Silver5.3
Hell no. No head work needed at all. Stab the cam, install the springs and give her hell. The ZO6 springs will fit the 4.8, 5.3, 5.7 and 6.0.
If it came out of a regular C5, then it is a LS1, not a LS6. And if it’s a LS1 then I wouldn’t run that much lift with stock springs. I’m not sure if you are considering LS6 spring swap as no headwork or not, but you need a better spring then the stock LS1 springs…
byrne_06
Apr 29, 2017 02:19 PM
nrmskate
Aug 11, 2015 02:44 PM
RONIN LSX
Aug 11, 2015 12:03 AM
Aboss
Jul 9, 2015 10:28 AM
Black-Syde
Jul 6, 2015 02:12 PM
