ls1/ls6 intake
Old Jan 28, 2010 | 08:52 PM
rubrhammer's Avatar
I have to go to a car intake due to hood clearance problems and for the past week have been researching this topic ad nauseum. The end result is as you were told, LS1 manifold ports flow worse up to .500 lift. The LS6 will flow better across the lift range and rpm range. However, you will pay $325 and up for LS6 vs $50 shipped for LS1. The project I'm building doesn't reqire big HP numbers so I cheaped out with an LS1.
Keep what you have unless you plan on spinning 6k rpm or more. If you are the LS6 is more manifold for the buck than a FAST.IMHO
Bob
Old Jan 28, 2010 | 08:55 PM
Wheatley's Avatar
Truck Sponsor
I would not go with the LS1 manifold personally.
Old Jan 29, 2010 | 12:51 AM
02'Z71ONDUBZ''s Avatar
What about a TBSS manifold? On the 07' and up trucks now as well, correct? A better option than any mentioned yet IMO. Power characteristics needed for a truck, in a 90mm TB setup (maybe 87mm, not sure). Probably would net very comparable gains to the ls6 in hp and torque.
Old Jan 29, 2010 | 11:20 AM
budhayes3's Avatar
PT's Slowest Truck
There was a good thread about the TBSS manifold recently, it showed some impressive gains throughout the RPM band.
Old Jan 29, 2010 | 12:11 PM
03 True Fire's Avatar
Good call, as mentioned the LS1 intake is inferior to the truck manifold, and a few members here have done the LS6 intake swap with little to no gain for a lot of work and dough.
ha ok so i hear! thanks for the clear up
Old Jan 29, 2010 | 12:14 PM
i havent seen much about gains from the tbss, but i see them for sale quite a bit
chvy=power
Oct 20, 2015 09:08 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
