LS1 Intake/Truck Intake
Old Feb 12, 2009 | 11:26 AM
Old Buzzard's Avatar
Thumbs up Thanks!
Looks like a "rethink" is in line!
Old Feb 12, 2009 | 09:52 PM
71camaro's Avatar
I read somewhere that one reason ppl swap over to the LS6 intake over the truck intake is the truck intake drops off peak hp at 5800 rpm or something like that. So switching to the LS6 intake keeps you building power past 6k rpms. Of course that would have to depend on your cam as well. I have a LS6 cam in my LQ9 and after 6k rpm it seems to stop pulling as hard. Is that due to the truck intake?
Old Feb 12, 2009 | 09:57 PM
The truck intake has longer runners that help produce torque, so yeah swapping to an ls6 intake or aftermarket will help produce more power in the upper rpm range.
Old Feb 13, 2009 | 09:55 PM
chevysten's Avatar
Originally Posted by Mighty Whitey
if you're in to spending some cash on your truck, I'd look in to a set of headers. I know manifolds of now a days are a WHOLE lot better than in the past, but there's still room for improvement.
doesn't sanderson make a set of LS swap headers for the s-trucks?
Yea, they do, manifolds were free!Lol.I know I need to get a set of headers.I would love a set of long tubes that CPW make,but a little pricey.($1200 coated)
Old Feb 17, 2009 | 05:24 PM
71camaro's Avatar
Dude I got a set of BNIB Pacesetter LT coated Ill sell you. No need to spend that kind of money. PM if youre interested.
Old Feb 17, 2009 | 07:52 PM
chevysten's Avatar
It would be nice to put them on but they wont work with my setup.I just bought some Sanderson shorties,we'll see how they work.Mike
Old Feb 17, 2009 | 09:42 PM
closet red neck's Avatar
Worth it or not.........I've said it before and I'll say it again. If I swaped out my LS6 intake and put the truck intake back on, I would not run the times I'm running now. It's up to you on how fast you want to go.......some say 2tenths @ best(not worth the swap), every little bit helps. To me 2tenths is alot...ex. 12.60 to an 12.40...food for thought.
James
Old Feb 18, 2009 | 12:36 PM
v8
17,16,15,14,13,12,11 Drvr
You will lose money and track times switching to a car intake, myself,txsilverado can verify this, I ran a Large cam and truck intake to 7000 rpms without a problem or loss, afr was 12.2 @ wot and on short belt was 14.5 afr LOL don't bypass alt for short belt!!!
Old Feb 18, 2009 | 01:23 PM
ap2002's Avatar
i totally agree..... i personally would not do it.... i have seen 6.0, that swap over to a fast 90 and loose e/t!!!! unless you have a stroked motor 402+, other than that i think its worthless...
Old Feb 18, 2009 | 01:38 PM
carfreak07's Avatar
I have all the factory truck accesories and the factory truck intake....as you can see, it makes power all the way through!
In my opinion, I like the truck intake better than the LS6! I am installing the truck intake on an LS1 and six speed in an 87 monte carlo right now.....hoping that works real well.
Attached Thumbnails LS1 Intake/Truck Intake-ls1-truck-dyno-graph.jpg
File Type: doc
99bluefirebird
Sep 17, 2015 08:05 PM
chvy=power
Sep 8, 2015 11:06 AM
USMCvet0311
Sep 4, 2015 09:43 PM
turbo truck
Sep 2, 2015 09:58 PM
lxcoupe
Sep 2, 2015 12:58 AM
