ls1 intake swap to lq4
Old Nov 16, 2009 | 12:33 PM
dirt track racer 81's Avatar
below the power steering pump
Old Nov 25, 2009 | 06:55 AM
scatillac's Avatar
You can also use the later truck ('07-up) water pump and relocate your idler pulley using a longer bolt, a spacer and a longer belt. This is kind of a new take on an old method, which required a bracket for the idler.
The belt runs pretty close (~3/8") but doesn't touch and I've spun it to 6500 while data-logging.
I had to use the earlier C5 ('97) fuel rail because my truck had to have a return line. The cable bracket is fabbed.
I still need to deal with the intake tube and clean it up a bit.
Attached Thumbnails ls1 intake swap to lq4-mvc-001f.jpg   ls1 intake swap to lq4-mvc-002f.jpg   ls1 intake swap to lq4-mvc-003f.jpg
Old Nov 25, 2009 | 08:23 AM
What throttle body and fuel rails are you going to use? Don't forget that you are returnless.
Old Dec 2, 2009 | 10:01 AM
Butcherboy's Avatar
Thumbs up
I did the same setup with mine. This is what Mine looks like.
Justin.
GrooveCityZ71
Aug 31, 2015 12:05 PM
jaypowe11520
Jul 29, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
NuckenFuts
Jul 9, 2015 08:45 AM
Black-Syde
Jul 6, 2015 02:12 PM
