LS1 Injectors into a 2003 5.3
LS1TECH Sponsor
Originally Posted by XLR8NSS
There ain't NO WAY a multec II 43lb(rated at 58psi) injector will support 1000rwhp. At normal fuel pressure(58-59psi) those injectors should be good for 500rwhp maybe just a bit more.
Now you could double the fuel pressure BUT, try to find a pump that can supply fuel at 100+psi and pray that your injectors don't lock up from the high pressure. Pretty much all automobile fuel injectors are not made to operate at pressures like that.
Originally Posted by gonzo 6.0
wouldnt you already have 24LB. now?
Your 2003 5.3 injectors are 24.x pound injectors, unless you have the flex fuel option. If so, then you have over 30# injectors. From the looks of your mods, you don;t have a need for anything larger than the stock injector.
ktmrider - in 1999, the 4.8 and 5.3 had 21 pound injectors. Since then they all came with 24 pounders.
man i wonder if i need to step up to bigger injectors now. especially since i am stepping up to a 175 shot. i am putting in an inline walbro. hmmm. now i wonder if they would help out. i suppose the 8.1's would be enough as well. any suggestions whether i should or not.
Originally Posted by Yelo
Everyone here does know that the stock injectors will support ~425rwhp right ???......and those Multec II's are SERIOUS OVERKILL unless you are running a BIG turbo, those things will support ~1000rwhp with the right fuel pressure
Did this post somehow end up under my login name by mistake ????
you might want to log out next time then
