LS1 Injectors into a 2003 5.3
Anyone have any advice or tips on installing the Delphi 24lb. OEM sprayers on my 2003 GMC 5.3? I already got the OEM connectors from my GM Rep. (part#12576106). So, will I need to change my fuel press.regulator? Any help will be a Heavensent. Thanx
you can do it, here is a link to what will have to be done, thank xlr8nss
for this write up http://hauln.net/LS1Tech/truck/fuel_injector/index.html
BUT
you can get up to 43lb injectors that will just go right in. http://www.azspeed.com/muii43lbin.html. much easier, most people only do the conversion when they want to go over the 43lb's
for this write up http://hauln.net/LS1Tech/truck/fuel_injector/index.htmlBUT
Everyone here does know that the stock injectors will support ~425rwhp right ???......and those Multec II's are SERIOUS OVERKILL unless you are running a BIG turbo, those things will support ~1000rwhp with the right fuel pressure
Adkoonerstrator
There ain't NO WAY a multec II 43lb(rated at 58psi) injector will support 1000rwhp. At normal fuel pressure(58-59psi) those injectors should be good for 500rwhp maybe just a bit more.
Now you could double the fuel pressure BUT, try to find a pump that can supply fuel at 100+psi and pray that your injectors don't lock up from the high pressure. Pretty much all automobile fuel injectors are not made to operate at pressures like that.
