LS1 fan installs
Old May 7, 2006 | 01:16 PM
99LoweredSierra's Avatar
Default LS1 fan installs
What do most people use to install? Make brackets?
Old May 7, 2006 | 01:37 PM
5.3 racer's Avatar
yep. i drilled 2 holes in the lower rad support for the existing fan brackets to bolt to and i used 2 pieces of aluminum strap to hold the top of the fans to the rad support.
Old May 7, 2006 | 01:40 PM
virgils4.85spd's Avatar
Default Go to the...
hardware store and get these little metal brackets. Thats what i used. Theyre about 5 in. long with holes drilled in them. They worked fine.
Derek
Old May 7, 2006 | 02:29 PM
Colby 04's Avatar
I used flat metal stock from Lowe's. It's in the hardware section.
Old May 7, 2006 | 09:34 PM
Quik's Avatar
5 year bitches!
large wire ties
Old May 7, 2006 | 10:56 PM
hahaha wire ties, thats what i would use easy cheap and strong....who needs it to be bolted on anyways
Old May 8, 2006 | 11:07 AM
i like stuff clean i guess i would have to buy brackets.
Old May 8, 2006 | 11:13 AM
Quik's Avatar
5 year bitches!
come look at my engine bay and its clean and hardly noticable with the ties. alot cleaner then brackets IMHO
oh yea less weight
Old May 8, 2006 | 11:51 AM
Yelo's Avatar
I've held a motor in a car with zip-ties (due to a broken motor-mount through-bolt) If they'll do that I'm pretty certain they'll hold a fan into a truck
Old May 8, 2006 | 12:31 PM
silver-mod-o's Avatar
Hunt&Fisherator
damn, thats some strong wire ties right there...
