ls1 crank pulley or 5.3 pulley
quick question... I have a 5.3 that I am playing with and I am useing ls1 accessories. Do I use the ls1 (camero) crank pulley or the 5.3? I don't know if there will be any balancing issues with the ls1 pulley or not.
No balancing issues, all ls engines are nuetral balance and any ls series pulley will work. Let me rephrase that. Any pulley will work BUT needs to be matched to the accessory system you're using. So if you're using LS1 accessories, use an LS1 pulley.
