LS1 coolant crossover tube questions...
Old Apr 14, 2010 | 09:10 PM
budhayes3's Avatar
PT's Slowest Truck
Default LS1 coolant crossover tube questions...
Will the LS1 front and rear coolant crossover tube assembly work with the truck intake, or are there clearance issues? Has anyone done it, and was there any fabbing involved if so? TIA
Old Apr 14, 2010 | 10:00 PM
slamdlsx's Avatar
thanks for asking lol. but the ls1 tube is all one piece and runs from the front and across the valley cover to the rear of the heads. not 2 diff tubes.
Old Apr 14, 2010 | 10:02 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, it looks kinda like a distorted H right? I guess I worded it wrong...
fixed it
Old Apr 14, 2010 | 10:07 PM
slamdlsx's Avatar
Old Apr 14, 2010 | 10:35 PM
Ferocity02's Avatar
I think it will fit. There seems be be a lot of room under a truck intake and I can't think of anything else that couldn't interfere with it.
Old Apr 15, 2010 | 12:03 AM
budhayes3's Avatar
PT's Slowest Truck
Test fit the intake trevor, if it clears, I'd run with it
Old Apr 15, 2010 | 12:39 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
It should fit. Plenty of room for the knock sensor harness, right?
Why do you want to run that x-over?
Old Apr 15, 2010 | 05:29 AM
slamdlsx's Avatar
ill test it out this afternoon. and this tube helps keep the coolant flowing more equally and runs cooler temps at the heads.
Old Apr 15, 2010 | 04:53 PM
JakeBrakeIH's Avatar
Yes it will work fine with the stock truck intake. I did this on my 5.3 in my older truck.
Old Apr 15, 2010 | 07:27 PM
slamdlsx's Avatar
sweet. yea i didnt get to test fit the intake today gonna try it out 2moro
