LS Truck Intake Shave Plastic Welding is Easy "How To"
Old Dec 14, 2014 | 10:13 PM
  #51
turbodriven04's Avatar
Registered User
Bringing this back up because I'm starting on mine right now.
AGearHead4Life, what did you use to cut all the excess off the top and the blind ports on the side? I was using a carbide bit in a dremel and it was melting it too bad. Also, I have found sheets of the Nylon 6/6 that could be molded to fit and cover everything up in one shot. Thanks
Old Dec 18, 2014 | 10:56 AM
  #52
AGearHead4Life's Avatar
I found the sawzall to work best. When I tried using a cutoff wheel it just clogged like your carbide.
Old Mar 21, 2016 | 06:32 AM
  #53
Blazeracer's Avatar
Just saw this thread as I did mine yesterday and was wondering if it was ever tested with boost. I used one of those oscillating cutters from Harbor Frieght to take the garb off. It worked GREAT!
I used a Mac Tools type 5 airless plastic welder to do the job. That thing melts the plastic in deep.
Mine's going on a jet boat running an LS1 with twin GT-35's at 18 PSI.
Attached Thumbnails LS Truck Intake Shave Plastic Welding is Easy "How To"-img_1483.jpg
Old Mar 21, 2016 | 07:44 AM
  #54
Choda's Avatar
wow looks awesome guys
Old Aug 14, 2017 | 07:02 PM
  #55
88stanger's Avatar
Registered User
Old thread but good idea.
Old Aug 15, 2017 | 04:43 PM
  #56
Tig's Avatar
Tig
I cant believe I haven't seen this before.
It looks amazing, nicely done.
I have a spare truck intake to, hmmm hahaha.
Tooooo many projects not enough time
Old Oct 24, 2017 | 11:20 PM
  #57
CAMSTER's Avatar
I appreciate info in this thread picked up a pretty good idea so I get to try something I have in mind with my intake, No I'm not going to cut it in half lol.
Old Nov 13, 2019 | 02:25 PM
  #58
Rob Schmidt's Avatar
Registered User
What size holes did you drill for relocating the vacuum ports and sensor? Also assuming you plastic welded those on to the rear of the intake?
ferrellrooster
Mar 6, 2025 03:22 PM
TA63
Mar 29, 2016 04:38 PM
Slammed96
Jul 27, 2015 07:22 AM
black6spdz
Jul 16, 2015 01:32 AM
jrplz
Jul 9, 2015 12:07 AM
