LS based engine swap Q's?
Old Jan 26, 2008 | 07:52 PM
Default LS based engine swap Q's?
Will an LS (aluminum) based engine swap right into an '04 silverado which currently has a 5.3? The motor mounts should be the same right? There shouldn't be any problems mounting up to the trans right? Thanks.
Old Jan 26, 2008 | 08:14 PM
Mangled03gmc's Avatar
Baltimore Whore
Yes everthing is a direct swap, just switch over to the truck acc, unless you are goung to run electric fans and the ls1 intake..
John
Old Jan 26, 2008 | 09:19 PM
John
Sweet. The truck oil pan fits that block?
Old Jan 26, 2008 | 09:50 PM
1Topgun's Avatar
That's right, it will bolt directly on. Basicly, the 4.8, 5.3, 6.0 as well as the LS1 and LS6 blocks, through 2006, have the same external dimensions and accept all bolt-on parts. There were some changes in 2007 to those blocks and the LS2, LS3, and LS7 (Gen IV) have some other differences, but I'm not sure of the details.
ARC
57
Feb 21, 2022 10:54 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Mark_k
Jul 9, 2015 12:37 AM
