ls-6 valves
Old Jul 5, 2009 | 09:38 PM
BigHate's Avatar
Default ls-6 valves
need some help deciding on the correct length pushrods. I have a LQ9 with a stock LS1 cam and 317 heads. I was gonna use a set of 243's but the valve seats had pits in them. so i took the valves and springs from the 243's to the 317's. how much longer are the hollow Z06 valves and can i use stock 7.4" pushrods. BTW just got the engine from the machine shop and they milled the block .005". thanks for any help!
Old Jul 5, 2009 | 10:04 PM
SincalT/A's Avatar
6mm or .236 longer.With the match of components you have a pushrod checker is in order.
Old Jul 6, 2009 | 09:56 PM
BigHate's Avatar
yeah a pushrod checker is gonna be a must. also i ordered the lifters alrady from gm and i have read all ls lifters are now ls7 lifters. from what i understand they have a different plunger height. thanks for the info.
Wolftrk99
Dec 3, 2015 08:12 PM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
