LQ9 Shortblock RPM Limits?
Old May 4, 2008 | 10:21 AM
SweetS10V8's Avatar
Default LQ9 Shortblock RPM Limits?
Hey guys, what RPM are safely truning your stock bottom ended LQ9s?
Im getting ready to do a cam swap and the valvetrain will be fine on limit speed. If I end up with a valvetrain that will spin 7000+ RPM, in control, Im not going to spin it there if the bottom end cant take it.
What are you guys shifting at?
Old May 4, 2008 | 11:14 AM
7845's Avatar
Banned
install rod bolts, good pushrods and dual springs...you should be fine if you have an intake that support that airflow like the ported fast. on tech youll see LQ9 spin 7k easy
Old May 4, 2008 | 11:16 AM
Stoichiometric's Avatar
+1 for rod bolts.
Old May 4, 2008 | 11:22 AM
SweetS10V8's Avatar
Im not tearing it apart at this point. Its in my S-10 already and Im doing a valvetrain upgrade and looking at what it will handle the way it is.
Old May 4, 2008 | 02:56 PM
shakesvho's Avatar
ARP Bolts are your friend
Old May 4, 2008 | 03:47 PM
ap2002's Avatar
i shift mine @ 6800 and the rev limiter is set @ 7250, I hit rev limiter only at the track when im doing the burnouts, its held mine, mine is stock bottom end with only comp cam springs and hardened pushrods... so I dont think you NEED rod bolts and such, by the way on my old 5.3 I had the same shiftpoints and rev limiter on that also, so go ahead dont be scared!!
Old May 4, 2008 | 09:06 PM
SweetS10V8's Avatar
Ive already got Comp springs and .105" wall pushrods. Im getting a new cam with Comps new LSL Lobes soon. 219/223 .607/.610 on a 112 +2.
Old May 4, 2008 | 09:48 PM
silveradol33's Avatar
you will be fine with a stock bottom end easy to 7k
FlowmasterMufflers
Nov 24, 2015 01:00 PM
lxcoupe
13
Nov 20, 2015 08:43 PM
chopperloco
Sep 28, 2015 08:40 AM
b4z
Sep 10, 2015 06:58 PM
Boyes50
Sep 8, 2015 12:06 PM
