LQ9 Question
Old Dec 8, 2003 | 01:29 PM
xXxSilveradoxXx's Avatar
BlownChevy I don't know how to quote you but, like, how awsome would 8psi be? Also, would a LQ9 be a good platform motor to build, or should I consider a Corvette Z06 engine or others? I mostly cruise and drive aggressivly and sometimes race.
Old Dec 8, 2003 | 06:03 PM
Flyer's Avatar
If you are gonna go with a blower of some sort, I'd start with the regular 6.0. Otherwise, yes, the LQ9 would be a good base motor. You might also consider the 5.7 for the lighter weight too.
Old Dec 8, 2003 | 06:51 PM
parish8's Avatar
single digit dreamer
lq4 is a much better choice for a blown 6.0 set up and is easier to find.
Old Dec 10, 2003 | 01:53 PM
I usually peak at 10lbs of boost with my truck. Its taking it pretty well. When its cold outside ive hit 12 PSI
Old Dec 10, 2003 | 09:31 PM
FarmTruc's Avatar
Performance Trucks Sponsor
The SS Silverado Radix with a stock pulley will boost about 5psi. With a 3.0" pulley, it will reach a max of 7psi, on this particular truck, max boost was at the top of 3rd gear.
'03 reg cab 5.3L, Radix with a 2.9" pulley will hit 9psi. This will require tuning for sure, get in touch with The_Mexican. After the tune and pulley that truck runs pretty good.
later,
allen
Old Dec 11, 2003 | 12:45 PM
marc_w's Avatar
Why does lower compression yeild lower boost?
If anything, I'd imagine the 'size' of the engine would change the amount of boost... not the CR.
Old Dec 11, 2003 | 02:46 PM
FarmTruc's Avatar
The SS radix and 5.3L radix are the same but come with different pullies,
usually you can't run a high compression engine with a lot of boost,
Old Dec 11, 2003 | 07:57 PM
So what's the diffrence between the LQ4 and the LQ9? Diffrent pistons? Is that it? There's gotta be something else diffrent. I plan on, whatever engine it may be, installing a forged rotating group, lower compression (8:1 maybe lower), and a rough idling cam and heads. Maybe bore increase, thats all the internal stuff I'll probably do. So by doing this I should probably get a LQ4? I'm confused...... my head hurts......
Old Dec 11, 2003 | 09:00 PM
FarmTruc's Avatar
lq9 block has a diff. cam and flat top pistons.
if you're going boost, get the lq4, no need for the extra expense,
Old Dec 12, 2003 | 07:41 AM
marc_w's Avatar
Okay, cool.
I thought I was hearing that the same S/C setup on a LQ4 will make less boost on a LQ9. (detonation aside) That one threw me for a loop!
chevy6.0fan
Aug 20, 2015 07:10 PM
Jblake
Aug 17, 2015 12:59 PM
The_W
Aug 15, 2015 08:07 AM
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
