LQ9 performance help
Old Feb 9, 2009 | 07:22 AM
  #21
Michael Halo's Avatar
bump!!! thanks
Old Feb 9, 2009 | 10:42 PM
  #22
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
If you have the 317 heads I'd get them ported and milled to bump the comp up with some solid springs.
Old Feb 10, 2009 | 07:18 AM
  #23
ya thats most likely what im going to do any advice how much i should mill them and what kind of springs the cam im going to use as a 588 lift
Old Feb 10, 2009 | 07:19 AM
  #24
KLUG'S SS's Avatar
FormerVendor
Originally Posted by Low_LQ4
If you have the 317 heads I'd get them ported and milled to bump to comp up with some solid springs.
Exactly! The 317s flow very well to start with in stock form so I would just have yours worked over some and milled down if you want some extra compression.
Old Feb 10, 2009 | 03:50 PM
  #25
Low_LSX's Avatar
What cam are you going to run?
Old Feb 10, 2009 | 06:15 PM
  #26
228/228 .588/.588 on 112lsa
Old Feb 10, 2009 | 06:37 PM
  #27
12sec.5.3's Avatar
The l92/l76 is really strong but not a direct swap. It involves retrofitting and modifying parts. Keep in mind you have flat top pistons on the lq9. If you mill the heads and go with a high lift cam, be sure you check the piston to valve clearance. Take it from me! Good luck on your project. It will be expensive and sometimes frustrating but is WELL worth every bit when running strong and smoking a lightning.
Old Feb 10, 2009 | 11:26 PM
  #28
Low_LSX's Avatar
lol that's the cam that I have now do you have a stall?
Old Feb 11, 2009 | 07:40 AM
  #29
realy how does it work in your truck does it go good? o and im working on a 3000 or 3200 stall not sure of the pi or yank or cri d
Old Feb 11, 2009 | 12:45 PM
  #30
Low_LSX's Avatar
It's not in the truck yet hopefully by next week. I ordered an Edge converter 3200 stall That's what texas speed recommended for the 228R.
