View Poll Results: Patriot or WCCH LQ9 heads
Patriot LQ9 heads
35.00%
WCCH LQ9 heads
65.00%
Voters: 20. You may not vote on this poll
LQ9 heads: Patriot or WCCH and why
Old Nov 20, 2005 | 10:49 PM
  #21
Originally Posted by JimS
FLP sells Darts, $1279.99 assembled. www.flp2win.com
so if stock heads are 71cc, what are those? i need to be around 9.5:1cr.
Old Nov 20, 2005 | 11:06 PM
  #22
02sierraz71_5.3's Avatar
alot smaller cc than what you want
Old Nov 21, 2005 | 05:22 AM
  #23
mattrem's Avatar
They are 62cc, They will put the compression way up.
Old Nov 21, 2005 | 06:20 AM
  #24
JimS's Avatar
I don't understand what's wrong with running higher compression and less boost rather than lower compression and then turning up the boost.
Old Nov 21, 2005 | 06:34 AM
  #25
TurboGibbs's Avatar
You get more HP out of boost than you do out of the compression, within reason of course.
Old Nov 21, 2005 | 01:19 PM
  #26
SS_bnoon_SS's Avatar
Don't forget that the Darts are new castings with thicker decks than the stockers. You can deshroud for the LQ9's larger bore, then cc the chamber to be large enough to run boost if that's the intent.
Old Nov 21, 2005 | 08:37 PM
  #27
2bseen's Avatar
11 Second Truck Club
I have had great results out of the patriot heads, I have had 4 diff. pairs on my truck since it had 1800 miles on it.
Old Nov 21, 2005 | 10:10 PM
  #28
why would you have needed to use 4 different pairs of heads? just wondering.
Old Nov 21, 2005 | 10:15 PM
  #29
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Thats what Im trying to tell everyone. The shoip near me charges 175 to do the chambers however you want them. I can get them cheaper than anyone has posted up Denali if you want same place that I told oyu about the rotating assembly.
PM me for more details.
Old Nov 21, 2005 | 10:30 PM
  #30
2bseen's Avatar
3 diff. setup heads on 6.0, and stage 3 ls6 heads on the 408.
