LQ4, LQ9; true or false
I read somewhere that the only difference between the LQ9 and the LQ4 was that the LQ9 pistons have a flat surface, and that the LQ4s pistons have a bowl shapped. I read that this is what gives the LQ9 more power and compresion. Is this true. If this is true, then all I would have to do is take a LQ4 block and put in LQ9 pistons and the LQ4 would have the power of a LQ9.
True or False
Thanks
True or False
Thanks
Banned
The Heads Are Also Different The Lq9 Heads Are Compare To The Zo6 Heads With Out The Lighter Valves The Flow Numbers Are Also Differentstock To Stock. Comprssion Is Not Going To Give You That Much Hp Difference.lq9 Has 10.4 And Lq4 Has 9.8.not Even A Whole Piont.07 Difference. Not 45 Hp Worth.
Go To The Dealer And See The Out Come And Then You Will Know Were I Got That Info. From.
I've got an LQ9 with the same heads as my LQ4, casting 317. I pulled an LQ9 from an escalade last year and it had casting 317 heads, same as my SS and all the other LQ4s out there. Try again.
Jason, the heads are the same. The pistons and connecting rods are different in the LQ9. Pistons are a floating pin design and have a coated piston skirt with a flat top, and the rods are noticeably thicker. LQ4 pistons have press fir wrist pins and are cast with about a 7cc dish in the top to lower compression.
Get A Vin Off Of Two Trucks With One With Lq9 And One With Lq4 And Go To The Dealer And See The Out Come And Then You Will Know Were I Got That Info. From.
How about sharing where you got this infinite wisdom from??? I am willing to bet you are off a bit on that claim.
Give me a PM
