LQ4, LQ9; true or false
Old Feb 16, 2005 | 09:12 PM
99Silver6.0's Avatar
317 cast is a 317 cast. The stealer is probably getting confused about the iron heads and the alum heads of different year 6.0's.
LQ4's got dished slugs. LQ9's got flat tops and beefier con-rods.
Old Feb 16, 2005 | 09:15 PM
02sierraz71_5.3's Avatar
whats the point of the dished pistons?
more complete combustion?
Old Feb 16, 2005 | 09:16 PM
Less compression and they can use the same heads.
Old Feb 16, 2005 | 09:17 PM
why would you want less comression, is it so you can run the cheap gas?
Old Feb 16, 2005 | 09:18 PM
litreddevil's Avatar
Banned
well if you think they are the same then you go ahead and use them you use the ones off the lq4 and sell me the ones off of the lq9
sorry dont mean to steal thread just rambling questions
Old Feb 16, 2005 | 09:19 PM
BlownChevy's Avatar
blownerator
25 Year Member
Why don’t you enlighten us? I am asking you to share your knowledge here.
Old Feb 16, 2005 | 09:21 PM
What year motors are you talking about man?? There are 2 cast numbers, 317 and 035. But head specs are exactlly the same. But the 317 and 035 heads were cast differently. The 317's were sand cast and the 035's were die cast. Thats the only difference. I havent heard of anybody with 035 heads on anything. Plus all I have ever seen or come across on a 6.0 are 317's.
Old post by ValveGod:
"If you look up in GM parts, the 035 casting reflects the head part number that is used on the CNG/LPG head for 2003. the diff. is the harndened valve seats. Both the 317 and 035 have been found on both LQ4 and LQ9. GM always gives a different casting number for a different process."
Old Feb 16, 2005 | 09:29 PM
David Cairns's Avatar
Originally Posted by Jason H. Rea
...and that the LQ4s pistons have a bowel shapped.
Thanks
eeeeeewww!!!!!
I guess that would make for "crappy" peformance!!!!!
Old Feb 16, 2005 | 09:34 PM
Jason H. Rea's Avatar
Thumbs up
Don't worry about it, the more we figure out the differences between these motors that better it will be for newbies like me
