LQ4 DD friendly Cam?
Old Oct 16, 2012 | 08:56 PM
LaCamionetaGris's Avatar
Question LQ4 DD friendly Cam?
Looking a for a good DD friendly cam for my FBO lq4 also have stock 243 heads to match the cam, for truck in my sig, using 4l80e w/ 3.90 gears, want the truck to run 12's NA.
CAI, full 3" exhaust LT headers, UDP, eFans, TBSS intake, tune current mods...
Old Oct 16, 2012 | 09:11 PM
Cakes's Avatar
I run a very similar setup to your truck minus the 243 heads (less compression on my truck) and I run the EPS 222/226 cam. This is essentially a better, newer version of the venerable TR224. I drive it everyday. It has great low and mid range power and pretty decent up top. It has a bit of a lopey idle. I think you will like it.
I am planning on installing a Magnacharger on top of this shortly and I think it will run well.
Old Oct 16, 2012 | 11:00 PM
grey matter 04's Avatar
13 Second Truck Club
216/224 or 220/224 vinci cams
tr224
would be my choices
Old Oct 16, 2012 | 11:10 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
216/224 should make you happy.
Old Oct 17, 2012 | 10:58 AM
^^^ these cam seem really small for 6.0, with the cams above + 243 heads is it possible to run 12s NA
Old Oct 17, 2012 | 11:12 AM
Cakes's Avatar
The issue you will see here is what people's tolerance for cams are and still be "daily driven" I chose my cam (with the help of Geoff @ EPS) because I have a 4WD truck which is somewhere around 400 lbs heavier than the 2WD version and I do truly use my truck as a daily driver. Would I like to be 12's NA...sure, but that is not why I put this cam in my truck. I wanted a fun street truck with good "all around" power and I think I have achieved that. Because of this, I am looking for more "all around" power and am planning on adding a Magnacharger.
Old Oct 17, 2012 | 11:37 AM
I think high 12's would not be a problem, if you can hook, and have a good tune.
Old Oct 19, 2012 | 08:49 PM
low2001gmc's Avatar
tr224 is an excellent choice. had it in a lq4 with 243s with a 3200 stall and 3.73s. what stall will you be using?
Old Oct 20, 2012 | 12:15 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
im running a 226/230 600/600 111+3 in my heads cam LQ4 with 243 heads made 395RWHP 375RWTQ on a mustang dyno and its very streetable and has a nice choppy idle
ARC
57
Feb 21, 2022 10:54 AM
2500ZL1
Jan 25, 2016 06:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
darnie
Aug 10, 2015 10:25 AM
jaypowe11520
Jul 29, 2015 07:59 PM
