LQ4 crank bolt missing
Old Feb 1, 2015 | 11:39 AM
George C....'s Avatar
Formerly ScreamingL
I've reused a stock crank bolt few times, just don't draw pulley on with the bolt
Use semi perm loctite and call it a day
Old Feb 1, 2015 | 12:32 PM
DAH32's Avatar
I dont have neither.
When I get to rebuild the engine, I see will about getting one.
Old Feb 1, 2015 | 02:59 PM
Formerly ScreamingL
New motor go new
Old Feb 1, 2015 | 03:11 PM
TXsilverado's Avatar
a new bolt is just over $3. if you're not in some kind of pinch, just call up sdpc and get a new bolt, or swing by your local stealership. I've re-used a stock bolt with no issues. but for 3$, why not go new.
hit up dirttrackracer for a pulley install tool it works like a charm...mine paid for itself bigtime. I bought a l76 that the threads were funked up in the crank. a little oil, patients and that tool, I was able to chase the crank threads out perfect.
Old Feb 1, 2015 | 09:11 PM
DAH32's Avatar
All right, one way or another, I'll have a bolt.
Thanks.
Old Feb 3, 2015 | 09:59 AM
gagliano7's Avatar
Don't use the stock bolt to pull on the balancer!!! You will strip out the threads in the crank. Buy or rent installer tool.
Old Feb 3, 2015 | 09:38 PM
mdwatts11's Avatar
Or use an LS7 bolt thats a lot longer than stock.
Old Feb 3, 2015 | 11:01 PM
GMCtrk's Avatar
That's a cool trick - never heard of that one. How much does the bolt cost?
Old Feb 4, 2015 | 05:32 AM
Formerly ScreamingL
Still don't use any bolt, buy a installer
Old Feb 4, 2015 | 11:28 AM
I agree...I've pulled many crank pulleys on with the stock bolt and luckily never had a problem. after getting an installer, it took all of the worry away when pulling a pulley onto the crank.
