lq4 build
Old Nov 25, 2009 | 07:51 AM
DAH32's Avatar
Default lq4 build
Anyone what to throw out there a build for a 400 horse and 450 torque lq4?
Old Nov 25, 2009 | 08:17 AM
Use the search button above you.
First off, what kind of money are you wanting to put into it?
Old Nov 25, 2009 | 08:38 AM
DAH32's Avatar
OK.. I have used the search function, but have not found anything in exactly how to upgrade a existing lq4. Alot of the threads talk about changing the heads, intake, a bump in compression to run bigger cam.
I really do not want a big dollar motor. What I'm interested in is the following. I currently spray a 125 shot on top of a stock lq4. Good power off the bottle and on. What I would like to do is upgrade the current 325 horse to 340 horse motor to about 400 horse.
The motor has about 70,000 miles on it.
I would like to use as much of the lq4 parts as possible to keep cost down.
I'm not opposed to getting a lq9 and refreshing it either.
Old Nov 25, 2009 | 10:42 AM
Bromaguire's Avatar
What if I had 8-10k to use on a lq4 build with a blower. What would you do to the motor?
Old Nov 25, 2009 | 11:31 AM
AndysC3's Avatar
for the op. Headers, a mild 22x/22x cam, a set of 243 heads, and a very healthy tune should get you close. Keep an eye in the for sale section.
Old Nov 25, 2009 | 02:45 PM
You would be better off than me. Call some performance shops and get some prices of a 370 or 408.
word!!!
Old Nov 25, 2009 | 05:36 PM
Bromaguire's Avatar
The shop the services my Denali for me is going to do my build. They build some crazy engines everyday for a lot of race teams. 1800hp N/A motors are a common site at the shop. They told me they could build me a mild 408 for around 8k that would make around 550-600whp with my blower. I just want to compare what others have paid for similar builds. I am going to replace the heads, crankshaft, pistons, rods, valves, etc.
Old Nov 25, 2009 | 06:51 PM
Should be around the 5-6K range for a longblock. 408's typically run about 3-4 depending what all parts you use. Mild 408 for 8k seems a little high to me. I'm starting a 408 build myself. I know is something that everyone does but I like knowing what I'm getting into. I will be doing all of the work myself. Well, all except for the boring and balancing. Just trying to figure out now which brands to go with.
