LQ4 + 706 heads
Old 02-21-2019, 10:18 PM
NVR MISS's Avatar
Default LQ4 + 706 heads
Little build put together for a 4x4. Focusing on good low end/mid range grunt, with a little extended rpm fun. Budget friendly oriented.
- Stock LQ4 bottom end
- 706 heads: Milled down 3cc to a 58.5cc combustion chamber
- Tbss intake: Mouth opened up just about to 102mm, ported the inlet as far as possible w/out having to hack it open. Also ported the runners as far down as possible. The transition from the mouth to the inlet is very nice. Pics below
- Camshaft (222/232) .595”/.587” 108LSA +3
- 1 7/8” long tubes
​​​​​​- 3” off-road Y, into single 4”
- Circle D 3600
- 4.56 gears
- PerformaBuilt LVL III 65e Trans
- 35-12.5-r17 tires
- E85 & 93oct, will be tuned on both, but will always run on E, as ethanol is of quality and readily available down here in Houston, TX ����
Any guesses on what it’ll produce at the wheel?
Old 02-23-2019, 12:07 PM
NVR MISS's Avatar
Fuel pump maxed out @5100rpm on E85, making 375whp/375ft-lbs. Going to run a 93oct tune for now until I get another pump in. Waiting on 93oct numbers
Will post dyno sheets later on.
Quite impressed with numbers through the 4x4 drivetrain and big 35” tires. Tuned by Bryan @PowerFab in Houston, TX.
The following 2 users liked this post by NVR MISS:
Bluecollar Hotrods (03-16-2019), Jaysz28 (03-17-2019)
Old 03-16-2019, 12:22 PM
10 Second Club
Really good #s considering the drivetrain loss.
Old 03-16-2019, 02:34 PM
madmann26's Avatar
That's encouraging for me with my 370/706 heads and 80e.
Old 03-16-2019, 02:46 PM
Laid Back
Beatdown Z's Avatar
Good numbers! How’s it feel?
Old 03-17-2019, 04:54 PM
Jaysz28's Avatar
I've been considering a similar build for my tow pig
but the more I add up the cost of everything, I may just sell my truck and go diesel shopping.
denali_on_26's
09-01-2017 03:14 PM
Doc_speeder
02-27-2012 10:55 PM
454navyss
12-28-2011 06:54 PM
denali_on_26's
04-22-2011 05:58 PM
lsx10
11-20-2008 09:52 PM
Quick Reply: LQ4 + 706 heads
