LQ4 6.0 + 5.3L heads =
I would expect it to be in a range over 12:1 compression. The stock 5.3 pistons are dished the 6.0 you would put them on would have flat tops, plus the cc diameter is smaller than the bore. Then if you have any aftermarket cam I would really worry about valve to piston clearance. By the time a machine shop reworked the 5.3 heads for larger valves, seates and expanded the cc to match the bore size it would be expensive.
But I dont know of anyone thats done it and it would be interesting to hear about it, Im shore you could get them to flow really well with an aggressive port job and they would probably have alot of velocity.
Hmmm...
What are the major differences between the 5.3 and 6.0 heads obviously cc size and larger ports.
Are there any other major differences? Valve angles, location of valves, spark plugs, injectors?
Hmmm...
Hmmm...
Hmmm...
Originally Posted by 99Silver5.3
LQ4 doesnt have flat tops. A worked set of 317's would flow a lot better than 5.3 heads would. 317's have bigger valves too. Injectors are 24.7lb/hr just like a 5.3.
Originally Posted by redaddiction
Are you sure the 6.0 heads have bigger valves ?
LQ4 doesnt have flat tops. A worked set of 317's would flow a lot better than 5.3 heads would. 317's have a bigger int valve too. Injectors are 24.7lb/hr just like a 5.3.
tea heads from thier website
5.3 stage 3 intake-319.6 exhaust-276
$1,679.80
6.0 stage 3 intake-334.0 exhaust-277.1
$2,262.45
The valves are slightly larger on the 6.0 intake side .003 the exhaust is the same. For the money Id take the 5.3 and the velocity is probably better why do you think the f body guys use them and not milled 6.0 heads
Originally Posted by SportSide 5.3
dang... your buddy Todd (12sec5.3) ripped me off then.
Originally Posted by LedFut
Oh they dont? My worked over 5.3L heads flow 330cfm on the intake side.
The valves are smaller in the #862 castings due to the tighter bore diameter ( 3.78" vs 3.898" and 4.00" ). You would get "valve shielding" with the smaller bores and cause reduced airflow and turbulence when the valves get too close to the cylinder walls.
330 at what lift??? Not too sure your heads are STOCK. Are they? Were talking stock heads here. In stock form, 5.3 heads on a 6.0 is a flat waste. CR will shoot to like 11:1 with 5.3 heads.
with the exception of the intake valve i don't believe there is any real change the the port causing a restriction. if you check around you'll find the 5.3 heads are a pretty good gain on the 5.7L applications. i think a 5.3L head on a 6.0L with the correct intake valve machined in would make more power than the 6.0L head let alone with some port work. it's not worth it as a straight forward swap, but well worth it with some minor work.
