lq4 402 help
Old Jan 6, 2012 | 06:58 PM
dkx's Avatar
dkx
Default lq4 402 help
I don't know a whole lot about the engine (no build sheet). I do know that it is a 402 with 241 heads and yellow valve springs. truck intake manifold with stock throttle body. the cam sounds weak also (no cam spec card). the truck dyno'ed 285 at the wheels with a manual vb 4l80, 2500 stall torque converter, 9" 5.43 ring&pinion and 37" tires. probably about a 30% drive train loss. I'm disappointed in the numbers. what can i do to squeeze out an extra 100rwhp naturally aspirated.
Old Jan 6, 2012 | 07:03 PM
AndysC3's Avatar
ditch the 37s.
Old Jan 6, 2012 | 07:31 PM
dkx's Avatar
dkx
i wish that was an option but given the nature of the truck, smaller tires would give me more problems.
Attached Thumbnails lq4 402 help-pic.jpg   lq4 402 help-pic1.jpg   lq4 402 help-pic2.jpg
Old Jan 7, 2012 | 05:08 PM
dkx's Avatar
dkx
Any and all advice is welcome.
Old Jan 7, 2012 | 05:13 PM
SlickSierra's Avatar
Different intake, throttle body, and cam/springs to start i would think.
Old Jan 7, 2012 | 06:02 PM
WhiteChevy3's Avatar
Trophy truck! Ayyeee!
Old Jan 8, 2012 | 11:25 AM
LS1TRUCKGUY's Avatar
as said above, intake/valvetrain addressed first. a popular upgrade is a tbss intake manifold with a 90mm throttlebody. im no guru but i would guess a cam in the high 220's/low 230's intake/exhaust duration would work well would that converter. also, is the trucks pcm tuned? i would think i 402 even if it was choked with a baby cam and small intake would easily make over 300hp even through an 80e and 37's
Old Jan 8, 2012 | 11:53 AM
JoeyGC5's Avatar
Very cool truck! On the dyno where did power peak at and after peak how bad ddi it fall off? As the others have suggested a good cam/heads/intake setup on the big cube motor will make aa world of difference, especially for what your using the truck for.
Old Jan 8, 2012 | 05:34 PM
dkx's Avatar
dkx
Thanks for the info. The truck was dyno tuned at Cunningham motorsports. I believe it made power between 3500-5800. Is the fast Lsxrt worth the time, or will I see similar improvements with the tbss intake? Are the 241 heads holding the engine back?
Old Jan 8, 2012 | 05:39 PM
dkx's Avatar
dkx
Most off-road trucks with 850 hp at the crank rarely see over 500 rwhp. Drive train is a real killer on rwhp.
