Low impedance injectors
Old Nov 28, 2006 | 05:35 PM
thunder550's Avatar
High on diesel fumes
Default Low impedance injectors
Looking at switching to an Acceleronics VersaFueler low impedance injector system. Anyone have experience with the low impedance injectors? I've heard they are much better at idle and part throttle when the injector pulse is very small. Heard that high impedance injectors are not matched well at all because of the opening and closing rates at low load.
Old Nov 28, 2006 | 05:45 PM
XLR8NSS's Avatar
Adkoonerstrator
I don't know about low impedance injector stuff but, do know that 57lb/hr @ 43.5psi Siemens high impedance injectors drive/idle fine in a basically stock 5.3L. They actually seemed better than the stock injectors and the SVO 42# injectors that were on the same engine.
How big of an injector were you looking at?
Old Nov 28, 2006 | 05:48 PM
thunder550's Avatar
Jeff @ Acceleronics recommended either the 83# or 96# injectors. They are the same price.
Old Nov 28, 2006 | 05:50 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I jut got my versafueler and 96#ers in the mail yesterday Ill let you know shortly, TurboBerserker is the only other person I know of running the versafueler, Parish was running his 96s off the BS3.
Old Nov 28, 2006 | 05:51 PM
XLR8NSS's Avatar
Adkoonerstrator
Damn, that is a whole lot of injector.
The biggest high z injectors I've heard of are 75# units. Don't hear much about them because by that time most people just change up to low z.
Old Nov 28, 2006 | 05:54 PM
1slow01Z71's Avatar
Dont wanna run out and the diff between the low z 75s and the 96s was nothing when ordering them through acceleronics so why not.
Old Nov 28, 2006 | 05:58 PM
dirt track racer 81's Avatar
what are svo injectors? low or high impedence?
Old Nov 28, 2006 | 06:01 PM
1slow01Z71's Avatar
High impedence they are ford style IIRC you have to change to the car style injector plug in order ot run them
Old Nov 28, 2006 | 06:12 PM
Sorry to Hijack the thread, What all would i have to change in the tune to get these to work? Quik has them and he sent me his tune but i couldnt ever get it to open up since he has hp and i got efi live..i already have the ls1 intake and stock ls1 injectors and they are at 120% duty cycle..i got svo red top injectors off a mustang i put a procharger on..so i was going to try these out
Old Nov 28, 2006 | 06:16 PM
1slow01Z71's Avatar
I dont know hardly anything about tuning I just know the pulse width of the injector will have to be shortened whether there is a table for that or adjusting the A/F ratio via the VE table. It would just require you retuning the whole damn thing pretty much since your injectors will be flowing twice as much at a given pulse width.
