low-end torque+ LSx motor, is it possible?
Old Apr 19, 2009 | 10:57 AM
  #51
PSM's Avatar
PSM
To add more to this thread... I've been reading a lot on ls1 tech and if you want to spend the money.. get a set of afr 205 heads and have them ported by Tony Mamo from AFR. All the reviews say it gives the motor amazing low end and throttle response. The intake ports are smaller than the stock 317 (205 vs 210 I believe) and they flow much more. That means huge port velocity, which means tq!
Old Apr 21, 2009 | 09:39 AM
  #52
Mark Johnson's Avatar
Now we're geting somewhere....................
Old Apr 21, 2009 | 04:22 PM
  #53
TURBHOE's Avatar
i guess i don't get it. did the old small blocks really have that much down low or did it just seem like it because it fell on its face so soon? has anybody ever dyno'd a newer and old truck stock for stock and see how the low end torque compared. it seems to me it may be similar but not feel like it because the 5.3 keeps going and feels better and better as it goes. i know mine has great low end and pulls fine. i have a buddy that pulled horses with his 1500 silverado 5.3. he had a cummins for doing this on normal basis but towed with the 5.3 when he needed to. granite i have a sc3200 from yank now but when it locks up its great. i went to the sc3200 from a tt3000. the tt300 was just too loose and felt like crap down low. felt like i had no power unless i had over 1/2 throttle. with the tight converter it feels way better. i was driving through mountains in Tennessee and the thing never down shifted and the tcc never unlocked. pulled them no problem. 35-40% throttle. i logged it.
but maybe its just me.
fond a site with some ls1 lt1 lt4 dyno's. stock for stock it doesn't look too much different in the down low area.
http://www.lt1.net/dyno.htm
Old Apr 21, 2009 | 09:16 PM
  #54
PSM's Avatar
PSM
What you are not seeing is the 0-2000 rpms where the older motors still had killer tq. Also the smaller intake runners meant part throttle tq was way up
Old Apr 21, 2009 | 10:50 PM
  #55
We gotta take the runners down to 185cc pr 180, even. Gotta weld up material in the port then smooth it out.................
Old Apr 22, 2009 | 12:38 AM
  #56
I have great low end torque on my truck. hell, part throttle and I cant keep it stuck from a stop, on 34" all terrains.
thats what i call great low end tq to me. Im probably about to lose that with the new setup, but I'll gain much more all over the rest of the powerband.
Old Apr 22, 2009 | 05:10 AM
  #57
PSM's Avatar
PSM
My first thought was because of the bore/strokecombo... but the 5.3/6.0 has a longer stroke than the 350. That really leads me to believe its in the heads
Old Apr 22, 2009 | 09:33 AM
  #58
The only answer is more cubes and/ or lower ring and pinions...........
Old Apr 22, 2009 | 11:16 AM
  #59
TURBHOE's Avatar
smaller runners as in shorter or thinner? 0-1500/1800 shouldn't matter stock stall does 1500-1800 does it not?
Old Apr 22, 2009 | 11:30 AM
  #60
Thinner. BTW, which are the best 5.3 heads; 706, 852 or 862..............
