Looking at getting LS1 Long Block, help?
Old Feb 19, 2012 | 08:54 PM
dmelvin's Avatar
Originally Posted by jrmchevyman
I would have bought it for that too, if I had the money at the time. I have seen them go around here for the same price.
For an off the shelf cam a 220 or 224 like stated would be good. Or a custom 22x/22x like a 222/22x, 220/22x, etc..
I like ls1 motors, kinda glad you did that instead of going to the 6.0 like 95% of the guys.
I was thinking something like a 222/226ish with something like a lift somewhere around the .570 area. I'm running a 3k stall currently.
I've looked into the 6.0 route, around here you can't get one with less than 150,000 miles without spending $1200-1500.
I don't know if I want to use the stock heads and mill them a hair for a bit of a compression boost. The 243's on my 5.3 are 60cc chambers, but I think that'll be too much compression, either I'll mill the 241's, or swap them out with the 243's and run thicker gaskets to offset the smaller chambers.
Old Feb 20, 2012 | 12:21 AM
grey matter 04's Avatar
13 Second Truck Club
60cc head on a ls1 is 11.27 to 1 with stock head gaskets
Dont be scared people run 5.3 heads all the time on ls1 motors.
yours vs stock 61.15cc 5.3 heads is only a small gain in compression
or you could run a thick gasket or -4cc dish pistons to lower compression.
-4cc dish piston would be 10.7 to 1
Old Feb 20, 2012 | 02:25 AM
gasmachine85's Avatar
I ran a set of milled down 5.3 heads on my ls1 in my old camaro with stock gaskets.... dont be a baby!
Old Feb 20, 2012 | 08:11 AM
TXSZ66AVLANCHE's Avatar
243 heads with 60cc chambers? Must have been really milled, stock they are 64.5cc
Old Feb 20, 2012 | 09:14 AM
dmelvin's Avatar
Milled .030
I guess even running around 11.25 CR... the cam will bleed some off too. I was just concerned running such a high CR if it starts to use oil. This is a DD truck. I think when I get the motor I'll run it up to the machine shop, have them put a fresh crosshatch in it, put the rotating assembly together, and new bearings.
Old Feb 20, 2012 | 08:19 PM
dmelvin's Avatar
54-418-11 - XFI RPM Hydraulic Roller Camshafts
I think this cam with 1.8 rockers is close to what I'm looking for. I'm on the fence about getting a Pat G cam. Not because I don't think he knows his stuff, but just because of how busy he is and the wait time.
Old Feb 20, 2012 | 08:43 PM
man idk that 222/226 has proven its self very well
Many guys on ls1 tech have broke 400hp easy with that cam
Have you seen the dyno sheets ? I was very impressed
Old Feb 20, 2012 | 09:06 PM
dmelvin's Avatar
No, I haven't seen them. I haven't really looked at many cams yet.
The 222/226 is an EPS lobe isn't it?
Nevermind... Found it. I'm thinking about going with beehive springs since this is a DD, or am I better off with getting a set of duals?
Old Feb 20, 2012 | 09:42 PM
yes EPS
i would run duals with that cam
Old Feb 21, 2012 | 12:24 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Another vote for dual springs. You'll be pulling some high rpm with that cam.
