Looked over logs ... 59.xx MAF readings
Old Apr 19, 2004 | 04:41 PM
Flyer's Avatar
Default Looked over logs ... 59.xx MAF readings
I remember reading Parish had his MAF maxed out at 60.01. Does anyone know a way around this in tuning?
Old Apr 19, 2004 | 05:24 PM
parish8's Avatar
single digit dreamer
i think you can change the scale so it shows more air but i dont think it actualy reads any more air. you can add fuel just with the PE vs rpm though, that is what i am going to do.
seth at cmotorsports told me a prety easy rule of thumb fueling, once the maf flatlines you need to add 3% fuel at each rpm point above that.
so if it maxes at 5000rpm you will want to add 3%fuel with the pe vs rpm chart at 5000rpm, then at 5400 add 3% to the previous number, then at 5800, add 3% to the previous number. sounds simple enuff to me. going to try it on friday i think.
Old Apr 19, 2004 | 07:10 PM
Hit Man X's Avatar
Out of sheer curosity, why not set the VE down low in the RPM range and scale it all the way through...not just when the MAF is maxed?
Or would that have an adverse effect on the MAF function?
Old Apr 19, 2004 | 07:32 PM
parish8's Avatar
i dont know what you just said.
i am talking about adding fuel based solely on rpm, it is easy to do in the power enrichment section.
Old Apr 19, 2004 | 07:35 PM
Hit Man X's Avatar
LOL, it's hard to explain what I'm thinking a lot. Also I missed the PE for VE also. hahaha
Like can you add fuel based on RPM alone from idle to 7000rpm (or whatever your max RPM is)? Basically you'd be going speed density I'd think that way.
Old Apr 19, 2004 | 07:42 PM
parish8's Avatar
it isn't speed density becasue your pcm can't see boost and you are past the max airflow it can see.
do you have a wideband? i dont think you need to worry about it just yet, you can hit 60.01 for awhile and nut run lean. i think i hit it at 5500 rpm and caried it to 6250 and my a/f ratio went from 12-1 up to 12.5-1, not the end of the world you see.
Old Apr 20, 2004 | 03:40 AM
Flyer's Avatar
I think what Parish was saying is in the PE tables (WOT throttle) you can add fuel where the MAF maxes at .. say it's maxing at 5k rpms, so add fuel at WOT from 5k up.
Parish ... it isn't a problem right now, but I'm still running a small cam and ONLY 7psi ... if you know what i mean ......
From what your saying though ... it sounds like it isn't going to be as big a problem as I thought it would be.
blownss27
Oct 27, 2015 11:42 AM
BIGD4504
Jul 28, 2015 11:46 AM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
DwDrummer
Jul 24, 2015 07:05 AM
Suburban2500
Jul 13, 2015 09:57 AM
