lm7 performance build
Old Oct 11, 2016 | 08:19 PM
gmtech2014's Avatar
Registered User
Default lm7 performance build
ive got an 2001 lm7 engine and would like to make it a 600+hp.
I would like it to be very mean. very open to turbo and or a supercharger.
thanks in advance
Old Oct 11, 2016 | 10:43 PM
FFDP's Avatar
What's your budget?
Can be done very "easy" with a turbo setup.
I'd recommend some stronger connecting rods for sure if the goal is over 600hp.
Trick turbo kit or KB racing turbo kit, 80lbs injectors, ISky triple 12 cam/new lifters/pushrods, stronger rods, other misc. stuff to go with it. A beefy transmission like a 4L80e. There is a ton of different ways you could go here with cam selection and all that crap, this was just an example of what could make 600hp.
Old Oct 12, 2016 | 12:53 AM
Blown06's Avatar
8 Second Truck Club
I built the LM7 that came in my truck and ran it for 4 years without ever taking a valve cover off. Probably 100 or so passes at the track and 3000-4000 hard street miles. Shift points where 7200 rpm. The majority of its life it was probably putting down 600 or so at the tire, then the last 1/4 of its life it was probably closer to 700-750 rwhp. I did it with a blower and still on the stock block, crank and 706 heads. Eagle rods, Mahle pistons, Comp valve train, Edelbrock Victor Jr. intake and a D1sc Procharger.
Old Oct 12, 2016 | 04:47 AM
slvrram's Avatar
What are you going to use it for? How long do you want it to last? Budget?
Old Oct 12, 2016 | 12:14 PM
gmtech2014's Avatar
Registered User
Truly don't have a budget but I understand I'll get what I pay for.
Old Oct 12, 2016 | 12:17 PM
gmtech2014's Avatar
Registered User
It's going in a 78 c20 reg long box pickup. use it as a daily driver and shows. also sometimes at the track. would like to have a 5 speed behind the lm7.
UV231 Project
Oct 22, 2016 06:55 PM
richincanada
Oct 18, 2016 02:05 PM
lxcoupe
Oct 13, 2016 07:31 PM
tylerj
Not Manufacturer Specific Parts
Oct 11, 2016 02:39 PM
Thoagland
Oct 9, 2016 01:40 PM
