LM7 To L33 Spec Sheet Differences
Great! Thank You Sir!
I listed only the differences between the two motors listed.
I ask the tuners in the crowd, although they seem small:
How do you see these differences effecting a tune?
Do you think these differences are what gave the L33 the 15HP over the LM7?
How do you see them effecting a Blowers output.
LM7 Left - L33 Right
Both are 2005
Compression Ratio
9.49:1 9.9:1
Camshaft Lobe Lift - Exhaust
6.96 mm 7.2 mm
0.274 in 0.283 in
Camshaft Lobe Lift - Intake
6.82 mm 7.2 mm
0.268 in 0.283 in
Valves - Valve Lift - Intake Valves
11.58 mm 12.24 mm
0.456 in 0.482 in
Valves - Valve Lift - Exhaust Valves
11.82 mm 12.24 mm
0.465 in 0.482 in
Both are 2005
Compression Ratio
9.49:1 9.9:1
6.96 mm 7.2 mm
0.274 in 0.283 in
6.82 mm 7.2 mm
0.268 in 0.283 in
11.58 mm 12.24 mm
0.456 in 0.482 in
11.82 mm 12.24 mm
0.465 in 0.482 in
Originally Posted by ludicrist2500hd
Some one at one time said the heads where different. what trans ? 60 or 65 ? mine is shifting good since i changed tow haul settings and removed all tqm
hp tuners . I learn a little every day. I have slowly bump the timing up and no ping yet it should be 87-90 today cant wait . Next is trailblazer converter, thorleys, and magnaflow . A friend has an 05 hpp3 but they realy don't change much in 87 oct tune .
btw I average around 17.8mpg to 18.7mpg. average driving 45 to 65 back roads with at least one run per day floored 1st and 2nd .
The Rock did you get your tune yet ?
lxcoupe
13
Nov 20, 2015 08:43 PM
zblee
Nov 11, 2015 12:41 AM
