LM7 To L33 Spec Sheet Differences
Old Jun 4, 2005 | 10:40 AM
therock's Avatar
Default Some LM7 To L33 Spec Sheet Differences Listed Here.
Great! Thank You Sir!
I listed only the differences between the two motors listed.
I ask the tuners in the crowd, although they seem small:
How do you see these differences effecting a tune?
Do you think these differences are what gave the L33 the 15HP over the LM7?
How do you see them effecting a Blowers output.
LM7 Left - L33 Right
Both are 2005
Compression Ratio
9.49:1 9.9:1
Camshaft Lobe Lift - Exhaust
6.96 mm 7.2 mm
0.274 in 0.283 in
Camshaft Lobe Lift - Intake
6.82 mm 7.2 mm
0.268 in 0.283 in
Valves - Valve Lift - Intake Valves
11.58 mm 12.24 mm
0.456 in 0.482 in
Valves - Valve Lift - Exhaust Valves
11.82 mm 12.24 mm
0.465 in 0.482 in
Old Jun 4, 2005 | 02:04 PM
just a different cam?
Old Jun 4, 2005 | 02:49 PM
therock's Avatar
Default And Compression.
Not to nick Pick.
Old Jun 4, 2005 | 07:00 PM
ludicrist2500hd's Avatar
Some one at one time said the heads where different. what trans ? 60 or 65 ? mine is shifting good since i changed tow haul settings and removed all tqm
Old Jun 4, 2005 | 11:13 PM
05GMCL33's Avatar
Ludicrist how did you change the trans settings on your L33, what programmer did you use or I mean how did you tune it.
Old Jun 5, 2005 | 04:55 AM
therock's Avatar
My RPO code shows a 4L60e. It was rumored to be a 65 but not mine.
Old Jun 5, 2005 | 08:58 AM
hp tuners . I learn a little every day. I have slowly bump the timing up and no ping yet it should be 87-90 today cant wait . Next is trailblazer converter, thorleys, and magnaflow . A friend has an 05 hpp3 but they realy don't change much in 87 oct tune .
btw I average around 17.8mpg to 18.7mpg. average driving 45 to 65 back roads with at least one run per day floored 1st and 2nd .
The Rock did you get your tune yet ?
Ws6ickness
Feb 5, 2016 02:42 PM
lxcoupe
13
Nov 20, 2015 08:43 PM
zblee
Nov 11, 2015 12:41 AM
Justin87gn
Sep 10, 2015 12:06 PM
chvy=power
Sep 8, 2015 11:06 AM
