It Lives!
Old Mar 25, 2006 | 07:59 PM
Question
Originally Posted by Dave68RT
Removed!
Sorry.... I don't get it.
Jim
Old Mar 25, 2006 | 09:14 PM
KySilverado's Avatar
Originally Posted by Z06 DREAMING
congrats on the upsize
how bad was the valvetrain noise? was there enough assembly lube on the cam? did you pour a little oil on the heads and such?... I'm sure it wasn't harmful though right?
congrats again
Valve train noise was bad. I put assembly lube on the cam before I stuck it in. Took a while for the lifters to pump up. I've put about 75 miles on it now and its fine. Well as fine as 918 springs get.
Old Mar 25, 2006 | 09:17 PM
Originally Posted by greentahoe
did you do anything to the 6.0 before you put it in? Was there anything that stuck out in your mind about the swap that you would warn others of? Did you swap out the rod bolts? Stock intake? Spill it
I did add Katech style rod bolts. The swap really went easy. No warnings. I would recommend just taking your time and marking everything well. I used masking tape and marked every electrical connections, took pictures, and placed all the similar bolts in sandwich baggies and marked them. IE: ground botls, power steering bracket, etc...
I've got a Radix so intake swap is out of the picture.
Old Mar 25, 2006 | 09:21 PM
Originally Posted by ap2002
did you end up changing cams?? or did you stick with your old one??
Yes I swapped cams. Had to. A cam lobe had scored up on the Cam Motion unit. That is what was making the noise that drove me to getting the 6.0. I went with Lingenfelter GT7.
So far it feels like I'm about the same power level down low. It PULLS much better mid to top I think.
Going to the track tomorrow.
Old Mar 25, 2006 | 09:22 PM
Removed!
Old Mar 25, 2006 | 09:25 PM
Originally Posted by TIM Z
Congrats man! you didnt mess around gettin that thing runnin! Its gonna feel like a new truck!
Thanks, I wanted to get it together quick as I could. Not going to have the chance to work on it much the next couple weeks. Work has me humping. Also a big shootout at the track I wanted to try and make tomorrow.
Old Mar 25, 2006 | 10:22 PM
ap2002's Avatar
make sure to post up the results tomorrow!!!
Old Mar 26, 2006 | 01:51 PM
Colby 04's Avatar
Is this an LQ4 6.0?
Old Mar 26, 2006 | 04:51 PM
Originally Posted by Colby 04
Is this an LQ4 6.0?
Yes. Went that route little cheaper and lower compression for boost.
Old Mar 26, 2006 | 04:56 PM
First pass down the track. 12.95 @ ?? (didn't record the mph)
Best for the day 12.921 @ 102.26! 1.85 60ft. Dropped my best ET by .5 and gained 3 mph.
