Limped the Ally last night
Old Oct 18, 2004 | 06:35 AM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Default Limped the Ally last night
I got my Quadzilla stealth on Friday and decided to stack it with Edge Hot Juice set on four.Well on levels one and two the truck ran like it never did before.I thought if two was this much fun I'll try it set on four.The truck ripped through the first four gears but on the 4-5 shift it was like it was in neutral and the engine lost a bunch of power.I pulled into a parking lot and hooked up the quad tuner,cleared the code and unloaded the program.Did I hurt anything?The truck runs and drives fine but I still wonder if I damaged my tranny.
Old Oct 18, 2004 | 10:26 AM
tbyrne's Avatar
That is pretty much a safety feature so you should be fine.
Old Oct 18, 2004 | 11:15 AM
1TRUESS's Avatar
So did you piggy-back the two?
Old Oct 21, 2004 | 12:17 AM
Well, as far as long term damage I'm not sure. But as for what was going on --- too much power. The stock Allison is only good upto 400-450 hp at the flywheel, when you go over that the overdrive clutchs start to slip. Go to atsdiesel.com and read up on the transmission basics of the allison and look into some of their performance upgrades before you do that again!
Blwn99x
Mar 24, 2023 11:14 AM
twake_410
Apr 14, 2016 09:58 PM
Chewy07
Nov 14, 2015 09:46 PM
bisqikss
Sep 27, 2015 09:40 PM
Justin87gn
Sep 10, 2015 12:06 PM
