a lil help if you will please
Old Apr 5, 2011 | 03:19 AM
4.85spd's Avatar
Default a lil help if you will please
ok so i think i have a 2005 chevy silverado 4.8 5 speed. well thats what the truck was the day it way born aways. i have had some trouble since day one that ive had it. check engine light for lean bank 1 and bank 2. the dealer has had it in and out of 3 shops. light still on. anyways it had a poweraid tb spacer and some weak cheap way to small cold air so they put all new fsock stuff on it with a new mass air. same part number mass air that was on truck. i pulled truck inside today to paly around and fix a few lil things and thought i would put the tb space back on. anyways come to find out after doing some looking my truck has a ls1 or ls2 intake. its not a truck intake. tb is atleast 1 or 2 inchs lower than the alt pulley. and the heads are stamped 862 at the front coners. anybody got a idea what i might have? only reason i ask is one of the shops would not work on my truck bc they said i have a ls1 car motor not truck motor. and now im thinking the lean prob is due to crack or something. did the 2005 4.8s come with 862s? ill post any pics if needed
Old Apr 5, 2011 | 03:42 AM
Suddog's Avatar
Those heads started life on 4.8/5.3's. Post pics of your engine/intake.
Old Apr 5, 2011 | 10:47 AM
4.85spd's Avatar
4.85spd's Avatar
Old Apr 5, 2011 | 10:48 AM
4.85spd's Avatar
Old Apr 5, 2011 | 10:49 AM
4.85spd's Avatar
ok hope this helps. sorry there with my phone tho. on a side note what size tb does the truck come with stock? this one seems huge and i have a very hard time getting the stock intake tube on it. and is there any way t tell if its a ls1 or ls2 intake?
Old Apr 5, 2011 | 10:53 AM
EVILGMC's Avatar
that is an ls2 car intake (05-06 gto or ls2 vette). is your block iron or aluminum? i know some of the ls1 guys would put 5.3 heads for a bump in compression. do some more digging and figure out what engine you have and then get in touch with one of our sponsor tuners or find a good local guy to put a custom tune in.
Old Apr 5, 2011 | 11:04 AM
4.85spd's Avatar
thank you. i will do some looking but im pretty sure its a iron block by the looks buti will try to fnd some cast numbers. its running the two belt set up and pulleys from the factory. and it being a ls2 intake mite be why its a dog on the low end but rele screams past 3500
Old Apr 7, 2011 | 12:10 AM
4.85spd's Avatar
ok so i take it the LS2 intake is worth keeping on the truck right? its going on the dyno and getting a tune i hope in the next 2 weeks. then a c.a.i with lt and y pipe by summer and a cam. comp 21/218 i think. will this intake help this set up?
Old Apr 13, 2011 | 02:39 PM
4.85spd's Avatar
There is a number on my block in front off passenger side head. Looks like 25L04. Any idea?
