Lifting the heads!!!
Old Jun 2, 2005 | 04:10 PM
Flyer's Avatar
I had some tip in KR, but I think most of it was headers banging around. I see ~1-2* of KR at most and that's very intermittant after a header change, before the header change, 5-7*.
They were torqued to 70 the 1st time and 75 the 2nd. The 2nd time around there was a LOT more attention to detail when I torqued them down.
Old Jun 2, 2005 | 05:59 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Flyer, I'm not sure what you have for fasteners, but I got some ARP L19 studs and torqued them to 100 on the mains, and 26 on the pinch studs.
Old Jun 2, 2005 | 08:23 PM
2CHEVYs's Avatar
On the mustang 5.0 i am used to if you over torque your intake bolts it will lift or make it easier for them to lift sound like that the case here go 5lbs less on the intake bolts.
Old Jun 2, 2005 | 09:56 PM
GMC SKI's Avatar
Quit messin around and get a set of AFR or Allpro head
They thicker deck surface will help out
or A set of cometics that's what's going on my next motor
you have head studs right if ya don't invest in a set
Old Jun 3, 2005 | 05:28 AM
Slowhawk's Avatar
LS1Tech Sponsor
I use the MLS gaskets and torque them to 80 ft/lbs.If they are lifting it is a good chance there is too much timing in the tune.
Old Jun 3, 2005 | 07:19 AM
hellbents10's Avatar
LS1Tech Sponsor
Do not need too. Stock heads, bolts adn gaskets are good for 1000fwhp or better. If you are lifting with less then that there is another problem lurking. There is a handful of cars well into the 8's with stock heads and gaskets with studs too.
Old Jun 3, 2005 | 07:38 AM
427's Avatar
427
My truck has stock bolts and stock mls gaskets. My boost has been as high as 22psi on the engine dyno. The engine now has 24,000 miles on the original gaskets. Best et is still 11.81@114.49 at 5500 pounds. Leaving today for Power tour.
Kurt
Old Jun 4, 2005 | 10:24 AM
Flyer's Avatar
Just an update on things ... dead in the water!
I went to torque down the final head the last time and ended up messing up one of the nuts on the stud. It pulled the threads out of the nut, but didn't do anything to the stud itself. Thunder is gonna hook me up on a new nut.
I was torqueing them to 85 lb/ft.
Turbo, where did you get the L19 studs and how much. You can PM me if you'd rather.
I hope this is the last time this happens. If I go through this again, I'm gonnaput the 5.3 heads back on. I think I remember when this happened, I was at the track and was running pretty hard. It may have gotten a little to hot, coolant and IAT's. The ambient temp out was something like 80-85 that night. It felt like it just sat down up top and took forever to get to the shift point from about 6000rpm.
Old Jun 4, 2005 | 10:35 AM
parish8's Avatar
single digit dreamer
i spit out a couple of head gaskets on my old motor. finialy i got serious about doing it right.
i had the heads surfaced, something like 005, head studs, stock 6.0 mls gaskets, motor oil for stud lube and 15 ft/lb's over what ever it said. i think i went to 90 ft/lbs with them. i got the block real clean but never checked it for warpage.
with that set up i had no more problems. i didn't see any more or any less KR after this so i dont think it was knock that was taking them out. i think it was either in imperfect head surface or the studs not being tight enough. i probably ran for 6months with that set up, lots of dyno runs and track runs. got my 640rwhp and 10.91 with that set up too.
Old Jun 4, 2005 | 10:54 AM
Flyer's Avatar
I'm thinking it's the studs. When I was talking with Thunder, they mentioned that it's not to terribly uncommon for them to back off after a couple of heat cycles. It makes sense too with the aluminum heads expanding and contracting. I'm hitting them with 85 ft/lbs this time, I think ARP mentioned 70.
I did spray some Tri-Foam on the studs for lube. It's like Liquid Wrench, but better.
