Lifter, piston or rod?
Old May 30, 2022 | 10:04 PM
  #31
codered161's Avatar
That be around 10.5:1
bore size is 3.780
Old May 30, 2022 | 10:09 PM
  #32
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by codered161
bore size is 3.780
When i went to the kit, it says 3.903 but is see that you can get a 3.780 bore.
Old May 30, 2022 | 10:10 PM
  #33
codered161's Avatar
yes sir, that’s the pistons I had selected when putting it together. The 3.780.
do you think 10.5:1 is too much or should I still look at the 317 and mill them? After bending a rod I want to get it right this time. Too many dollars lol
Old May 30, 2022 | 10:17 PM
  #34
1FastBrick's Avatar
Old May 30, 2022 | 10:20 PM
  #35
1FastBrick's Avatar
You could run a 243 head if your leaving the stock 3.780 bore
Old May 30, 2022 | 10:34 PM
  #36
codered161's Avatar
thank you for the knowledge and help! I’ll try and get my hands on some 243’s. Truck was down for about 2 months between me putting the turbo on and getting it tuned. I had it back a week and ended up with the bent rod. When I eased it over to the shop I noticed under light throttle afr was reading 16-16.5, at idle it was 14.5-14.7. I’m going to inspect my injectors while I have it apart and make sure one didn’t get stopped up some how.
Old May 30, 2022 | 10:48 PM
  #37
1FastBrick's Avatar
You are welcome!
Hope it helps.
FWI, The NEW Fuel's Don't last long. Be sure to use fresh fuel when tuning it.
Old May 31, 2022 | 05:01 AM
  #38
smokinlmm's Avatar
Yea^^ I had to drain my tank after the built motor was installed. It went bad in 6 months, that's retarded...
Old May 31, 2022 | 07:06 AM
  #39
codered161's Avatar
I keep fresh fuel in it. The tank seemed pretty clean when I installed the fuel pump 2 months ago.
Old May 31, 2022 | 07:19 AM
  #40
smokinlmm's Avatar
Anything wrong with running 243's on a 4" bore?
