lets talk cubic inches
5 year bitches!
lets talk about cubic inches and the amount of gains you see in power
lets put two motors together one a 364 and a 408 both have same setups but difference is 44 cubic inches now i know roughly thats a gain of 40 hp if i relate to the mustang sene. now what do you think honestly an dhow much more torque
i know thta one combo would be effiecent well other would be tamed but just wanting and idea on what to figure in on things
The bigger engine will often need a bigger cam, but really, setting these up identically won't prove much because the bigger engine can also use more fuel and air generally. It wouldn't be a huge advantage with identical parts, but the bigger engine would possibly last much longer too. Using the same cam would likely give the smaller engine a huge advantage in usable rpm.
will it be possible to make power at 7 grand? i guess it all depends on what you end up doing with the motor... its possible to turn it that high with the right rods/rod bolts, but question is, if it's making power up there
