Lets play...Name that broken part
Old Nov 17, 2005 | 11:06 PM
  #441
1SlowHoe's Avatar
Destroyer of Transmissions
Out of the blue question:
What is the compression ratio of my stock 5.3 vs. my new LQ4? I know the LQ4 can take a little more boost than the LQ9 safely because of the lower CR, is this true of the 5.3/LQ4? Just wondering.
Old Nov 18, 2005 | 01:08 PM
  #442
LVSTOGOFST2002's Avatar
as far as i know... both are 9.5:1 so same amount of boost safe probably...... good luck finishing up the install.... can't wait to hear the results.
Old Nov 18, 2005 | 05:28 PM
  #443
1SlowHoe's Avatar
Default Day 2
Got the tranny dropped. Finished installing the springs on the new engine. Drained the radiator, oil, etc...Got the fan pulled and half of the wiring harness unplugged when we were told to clean up?? The shop closes at 4 on Sat/Sun instead of 8. So we lost 4 hours today and tomorrow. Looks like this will roll into next week. Mark (the guy helping me) was really getting irritated with the Radix He has never installed a s/c before. Tomorrows plan is to finish pulling the engine, pin the crank, swap accessories, and put the stall and tranny back in. The Radix will be attempted Sunday or maybe Tuesday. Time flies when your having fun.
Question, Mark thought I couldn't use the fuel pump voltage booster with a return fuel sytem. Any reason why I can't?
Old Nov 18, 2005 | 05:42 PM
  #444
BlownChevy's Avatar
blownerator
25 Year Member
there is no reason why you cant use it on a return fuel system.
Old Nov 18, 2005 | 06:15 PM
  #445
Mr. Sandog's Avatar
Sweetness.
Old Nov 18, 2005 | 08:37 PM
  #446
O3GMC's Avatar
12 Second Club
belt should be the other way around the water pump:
I've changed the belt enough to spot that immediately
Old Nov 18, 2005 | 08:43 PM
  #447
1SlowHoe's Avatar
Hmmm. I'll have to look at that. I never had any slipping or any other issues the way it is in the pic. Whats the difference?
Old Nov 18, 2005 | 08:47 PM
  #448
O3GMC's Avatar
12 Second Club
I'm not sure, maybe the tentioner works better with the way it is on the diagram
Old Nov 18, 2005 | 08:52 PM
  #449
1SlowHoe's Avatar
That would have been self critiquing if the H2O pump was turning the wrong way lol! Watching the temp gauge climb steadily. Wonder if my belt will fit the right way? I did get a quick skreech if I nail it from a stop and drop off real quick before the 1-2 shift. Maybe the correct belt wrap would fix that. Thanks for the info
Old Nov 18, 2005 | 09:41 PM
  #450
BlownChevy's Avatar
blownerator
25 Year Member
LMAO I looked that that earlier and it just did not look right....Guess the daily tech calls are getting to me
I THINK you will have a problem with the way your water pump flows from the looks of the belt....I am all screwed up just looking at it
