Leaking LSXRT
#21
How would you mess up a formed composite manifold in shipping to make the ports sit uneven on the heads? I mean I think you would notice if it was damaged physically and to cause that it would have to be a mess. Unless of course you managed to heat it and twist it. It just wasn't formed correctly in the mold by the sounds of it, or the final machining ( if they even do any) wasn't done. It's kind of important to have your port face straight and apparently FAST forgot about that one on 2 seperate intakes in this instance.
Just sounds like a really poorly made overpriced POS.
Hopefully FAST is taking responsibility and at least refunding the OP for these messes.
#27
#28
#29
I know maybe a yr or so ago they also had a bad batch of hardened blanks or something similar and the facing was grooving/chipping and coming off. That was one of a few reasons why i decided to not get a comp ground cam..
Just add it to the list of comps great quality record..
#30
I've seen a few Comp cams with flat lobes, but I think that all of them were using Patriot Gold springs...maybe a spring issue or a bad combo of parts
I haven't heard of any of their pushrod failures...although I may just measure my Comp pushrod length checker to make sure that it's made right!
