Latté in my catch can?
Old Mar 9, 2014 | 08:33 AM
Chevy_King1500's Avatar
catch cans are over rated imo
Old Mar 9, 2014 | 08:54 AM
03sierraslt's Avatar
I am sorry but i have to disagree, mine only catches oil. Problem is that allot of people do not hook them up right and or have there PCV systems setup incorrectly.
Old Mar 9, 2014 | 09:38 AM
0235SS93's Avatar
Care to elaborate?
Old Mar 9, 2014 | 09:39 AM
Originally Posted by 0235SS93
Care to elaborate?
How is your PCV system setup?
To clarify I am not saying you guys all have yours setup wrong, just that I have seen many that are.
Old Mar 9, 2014 | 10:15 AM
0235SS93's Avatar
Hose from intake tube to pass. valve cover. How from dr valve cover to catchcan, to a check valve to the barb on blower inlet.
Old Mar 9, 2014 | 10:18 AM
Is the barb on the blower between the throttle body and the rotors? If so then a check valve is not needed as that location never sees boost. Where is your catch can physically mounted?
Old Mar 9, 2014 | 10:28 AM
Like Ferocity mentioned, location does seem to have a effect based off of temperature. Condensation is a common issue because the air coming into the can is hot from the engine and if the catch can is cool due to mounting location then there is where the condensation comes from. I always try to keep the catch can mounted to the motor so it retains heat. Mine is mounted to my passenger side head via a alum bracket so it gets warm. Every 1000m or so I check it and have maybe a tablespoon of brown oil and can still see the bottom of the catch can through the oil.
Old Mar 9, 2014 | 10:35 AM
0235SS93's Avatar
Yes, thats what i knew, but a $2 check valve cant hurt...the can is between the alternator and coolant ressie for the maggie. Ill get a pic after lunch.
Old Mar 9, 2014 | 10:40 AM
You just have to make sure the check valve still allows suffiecient flow.
Old Mar 9, 2014 | 04:45 PM
0235SS93's Avatar
Im sure it does, i could blow through it easily, but ill check the vacuum on the pcv hose after the valve.
