Latté in my catch can?
Like Ferocity mentioned, location does seem to have a effect based off of temperature. Condensation is a common issue because the air coming into the can is hot from the engine and if the catch can is cool due to mounting location then there is where the condensation comes from. I always try to keep the catch can mounted to the motor so it retains heat. Mine is mounted to my passenger side head via a alum bracket so it gets warm. Every 1000m or so I check it and have maybe a tablespoon of brown oil and can still see the bottom of the catch can through the oil.
Yes, thats what i knew, but a $2 check valve cant hurt...the can is between the alternator and coolant ressie for the maggie. Ill get a pic after lunch.
